275/35/18 Mock Up Complete - Team Camaro Tech
post #1 of 33 (permalink) Old May 19th, 07, 10:00 PM Thread Starter
My Wheel Mount Mate finally arrived this week. That gave me the opportunity to test fit my 275/35/18s on all four corners. The Nitto NT01s look crazy! Good news, it all fits. I'll be calling Frank (GPSuperstore) on Monday to order my Forgelines 18x9.5 ZX3Ps in gunmetal. http://www.forgeline.com/wheels/zx3p.html
Once they arrive I'll be ready to rock and roll on the installation of the Speedtech UCA and LCAs, ATS tall spindles, Hotchkis front springs and bar and C5 brakes.
I forgot pictures of the front mockup, but that's a lot of rubber up there. Quite a bit more than the 225/50/16s up front now...
Rear shots... compare a 255/50/17 on the right...
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #2 of 33 (permalink) Old May 20th, 07, 05:08 AM
Re: 275/35/18 Mock Up Complete
I would'nt be surprised if the inside of the tire rubs on the inner fenderwell in the front. You steering radius will most likely change . The backs look good.
Roadman is offline
post #3 of 33 (permalink) Old May 20th, 07, 06:56 AM
The NT101's do indeed look crazy. I like em!
Could (and would) you use that fancy gizmo to check clearance and backspace with that rubber on an 8" rim?
When I wear out my 255's, I'm thinking of going up a size, if they'll fit with my 4.5" BS wheels.
post #4 of 33 (permalink) Old May 20th, 07, 07:10 AM Thread Starter
you can use the tool to check width from 7" up, pretty much any backspace. It'll be for rent once I figure out the details. The hardest part was to get the car jacked up with weight on the suspension...
eville is offline
post #5 of 33 (permalink) Old May 20th, 07, 08:11 AM
Originally Posted by eville View Post
It'll be for rent once I figure out the details...
Ah yes, but you all ready have the 275 profile tires and proper size wheelwells!
post #6 of 33 (permalink) Old May 20th, 07, 08:29 AM Thread Starter
I needed some piece of mind before I ordered those wheels. If you buy tires from discounttiredirect.com you can send them back for just the price of return shipping. No shipping fee from them to you and no "restocking fee". Try it, don't fit, send it back for something else.
eville is offline
post #7 of 33 (permalink) Old May 21st, 07, 01:46 PM Thread Starter
just a quick update. I called Frank at gpsuperstore this morning and ordered my Forgelines. Frank was very helpful, he even called Forgeline while I was on the phone with him to confirm a couple of details including the 4 week build time.
Thanks Frank! I'll post pics when I get them!
eville is offline
post #8 of 33 (permalink) Old May 28th, 07, 10:01 AM
.gearhead.'s Avatar
Eville, that is going to look wicked. Please post a couple pics once you've installed them. I'm now leaning toward a setup similar to this. What rear backspacing are you ordering?
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #9 of 33 (permalink) Old May 28th, 07, 11:50 AM Thread Starter
I'll be sure to post pics. 3 weeks and counting on the wheels...
Rear backspacing for me was a little odd because I have a slightly narrowed rearend out of an early Nova. I'm afraid to post the numbers in fear of screwing someone up. If you really need 'em PM me.
eville is offline
post #10 of 33 (permalink) Old May 30th, 07, 02:44 PM
6D9
Ron
Looks good! Im running 18x10's out back on mine with 275/40/18's and it is a TIGHT fit.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #11 of 33 (permalink) Old May 31st, 07, 07:53 AM
Matt
Eville-
Are you running the original wheel wells in the rear? or is it tubbed?
Looks awesome BTW!
Camuchi is offline
post #12 of 33 (permalink) Old May 31st, 07, 09:01 AM
.gearhead.'s Avatar
Is the 69 wheel well or suspension different than the 68? I've heard they are, and may allow a larger wheel/tire combo. I'd like to do an 18x10 in my 68 but want to verify it can work first. I presently run a 15x8 Weld with 28x12.5 MT ET Streets and they fit just fine. Any advice?
Now: Boost...
post #13 of 33 (permalink) Old May 31st, 07, 09:40 AM Thread Starter
Originally Posted by Camuchi View Post
Eville-
Looks awesome BTW!
Original wheel wells. I might have to roll the lip after final fitment. (i hope not)
eville is offline
post #14 of 33 (permalink) Old May 31st, 07, 12:07 PM
6D9
Ron
They say a 69 has a bit more room than a 67-68 but I have not confirmed it. I really like the way the 275 BFG KD's look on the 10's. No puffy sidewalls at all. I think "streetfighter" on Pro touring.com is running 18x10's and 285/35/18's on his 68. With a 3" drop rear springs you will need rolled fender lips for sure.
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #15 of 33 (permalink) Old Jun 19th, 07, 08:47 PM
eville,
You have a PM.
Thanks,
ChassisPro is offline
'69 Complete SS 350 camaro_fever68 What's it worth? 21 Mar 10th, 09 02:40 PM
Complete rear frame rails? BB69 Body Shop 13 Oct 22nd, 06 10:51 AM
80 Z28 complete resto greenguy Restoration Corner 6 Oct 4th, 06 12:02 AM
Complete bushing set 67 Swedish Convertible Brakes, Suspension & Steering 5 Jun 24th, 06 05:08 PM
Complete Suspension rebuild cDuck28Z Brakes, Suspension & Steering 3 Mar 23rd, 06 02:18 PM
