18" wheel, what size tire? - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 2nd, 07, 07:52 AM Thread Starter
I've tried to read all of the posts about tire and wheel sizes, but I guess my brain isn't working well enough to figure it out. I am putting a 67 together and am planning on using a DSE tub kit for the back to help with wider tires, but don't know what size tire to use. I am looking at 18" American Racing Killer wheels that would be 8.5" wide in front and 10" wide in back. I will be getting a new Moser rear end and Wilwood disk brakes all around. Because I'm getting a new rear end, shouldn't I be able to use just about any offset? And after droping the car about 2", what would be a good size for the tires? Any advise or ideas is greatly appriciated.
diablo23 is offline
post #2 of 3 (permalink) Old Jun 2nd, 07, 02:27 PM
6D9
Ron
Re: 18" wheel, what size tire?
Im running 18's on mine. The fronts are 18x8's with 5" bs. Tires are 245/40/18 BFG KD's. Rears are 18x10's with 5.75" bs. Tires are 275/40/18 BFG KD's. This is on a 69 with trimmed fender lips. Front is lowered 2" and rear is 3". Either way its a very tight fit all the way around but man does it look sick............
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #3 of 3 (permalink) Old Jun 3rd, 07, 05:31 AM
With a DSE mini tub kit most people a running a 335/30-18 on a 12" wheel - the backspacing depends on the rear end width your going to use. I'm sure after you decide what that will be you can call DSE and they will tell you what backspace to order. If not you can post it here and we can probably help you out with it.
Jack
JV69z/28rs is offline
Need help on wheel tire combo Kelly Burns Wheels & Tires 1 May 8th, 06 05:23 PM
68 camaro - rear tire size ? JBCAMARO Wheels & Tires 2 Jun 26th, 05 05:03 PM
Does tire size effect gear ratio? 4U 2 NV Wheels & Tires 2 Mar 29th, 02 04:27 PM
Tire Size on '69 Z28 69DZ302 Wheels & Tires 8 Feb 23rd, 02 08:58 PM
best fit tire on a 10.5" wheel (18" wheel) ismail Wheels & Tires 1 Oct 16th, 01 09:10 PM
