18 Inch Wheels - Pics? - Team Camaro Tech
post #1 of 27 (permalink) Old Jun 23rd, 07, 08:41 PM Thread Starter
.gearhead.'s Avatar
Yes, I have searched through the threads and pics, and I have seen what is there. But, I don't see too many pics of 67-68 Camaros with 18" wheel/tire combinations. I realize why, but I'm different... I plan to install 18's on the rear and 17's on the front of my '68. I'm not sure about the rear width yet. I'd love 18x19.5 but can't find any with that width. I do like the ARE TTII's and Foose Nitrous wheels with black centers.
Please post up pics of 67-68 Camaros with 18" wheel/tire combinations. If you have spec's, I would appreciate that also. If you're aware of a wheel with 18x9.5 dimensions, please point me to it.
Thanks.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #2 of 27 (permalink) Old Jun 24th, 07, 06:36 PM Thread Starter
.gearhead.'s Avatar
Re: 18 Inch Wheels - Pics?
Anyone?
Now: Boost...
post #3 of 27 (permalink) Old Jun 24th, 07, 06:53 PM
I don't think there are many here with 18s. Check Lat-g and PT. I'll have some pictures soon when my forgelines arrive.
Check this thread over at PT.
http://www.pro-touring.com/forum/sho...%2F35%2F18
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #4 of 27 (permalink) Old Jun 24th, 07, 08:08 PM Thread Starter
.gearhead.'s Avatar
Thanks eville. I may join there and find out what type wheels are on that black '68 in the thread. I really like that vintage look with modern size.
Now: Boost...
post #5 of 27 (permalink) Old Jun 25th, 07, 05:57 AM
Plenty of 67 and 68 Camaros with 18's to reference here:
www.Lateral-g.net/members
69ProTouring is offline
post #6 of 27 (permalink) Old Jun 25th, 07, 09:07 AM
Brad
My 68 is on 18's..
Pics and details here:
http://musclesyndicate.com/m001.html
Founder MuscleSyndicate.com
Muscle Car Car Club
68 Camaro 468 - F1R Procharger - Converting to Procharged LS - in process now selling 468 BBC
whytry is offline
post #7 of 27 (permalink) Old Jun 25th, 07, 10:03 AM
DjD
DjD's Avatar
This is a sticky thread in this forum... It has a couple 18" pic's... You'll see most here are sticking with 17" and smaller.
https://www.camaros.net/forums/showthread.php?t=100853
...Dennis
DjD is offline
post #8 of 27 (permalink) Old Jun 25th, 07, 10:49 AM
ADAM
i have 18" on all 4 18/8 front 18/10 will get pics on a link again
68 ss clone sbc350 tko600 chassisworks , 69 LSX454 bbc (in progress jakes), 70 rs 454 mp500efi
AJSZR2326 is offline
post #9 of 27 (permalink) Old Jun 25th, 07, 02:55 PM Thread Starter
.gearhead.'s Avatar
69ProTouring, thanks for the link. Good info.
whytry, that's an incredible ride. What (if any) mods have you made to the rear end to allow the wheels to fit? I have measured and believe I can go with 18x10, but will try to get a 9.5" width somewhere...
AJSZR2326, please post a link when you can.
Now: Boost...
post #10 of 27 (permalink) Old Jun 25th, 07, 07:36 PM
Patrick
Budnik has 18.5. I have them on my 69, pics in sig.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #11 of 27 (permalink) Old Jun 26th, 07, 12:46 PM
Brad
Thanks! I wish I went wider than I have on there. I am only running 18x8's in the rear. I am probably going to call Budnik and get some wider ones made if I can fit them. I have to get my rearend done 1st, so I can measure twice and cut once... Last thing I need is to get the backspacing wrong... I would like to run 18x9.5 out back, with a 18x10 I think you need to be spot-on with your measurements and have little body roll or they can rub if you run a 285/40/18 which is what I would like to run...
Muscle Car Car Club
whytry is offline
post #12 of 27 (permalink) Old Jun 26th, 07, 04:18 PM Thread Starter
.gearhead.'s Avatar
whytry, now you're talking my language... Just confirming, you have not made modifications to your rear for the 18's, right? My measurements say I can go 18x9.5 so I want to be sure someone else is in the same boat.
I just checked Budnik's site. I do like several of their wheels, and the black powdercoat option. I'm leaning toward the Arrow, Fontana or Mercury. Also like your Fontanas.
Thanks.
Now: Boost...
post #13 of 27 (permalink) Old Jun 27th, 07, 08:40 AM
Brad
Yeah I have read and measured for a 18x9.5 and it will fit without rubbing issues if you run the 18x10 you have to be exact on the offset from what I have seen so far. What tire you planning on running? I am aiming for the 285/40's once I get the rearend in with new brakes... The only thing I did was roll the inner fenderwell and that was more for planning for future wider tires.... I originally was looking at running the 275/40 on the 18x8's I have now but I have been advised against it..... I agree with you on wheel choices, you have picked some good ones.....
Muscle Car Car Club
whytry is offline
post #14 of 27 (permalink) Old Jun 27th, 07, 09:18 AM Thread Starter
.gearhead.'s Avatar
I want to run the 285mm also on a 9.5" wheel. But I believe that width tire could be pushing it a bit, since I have not rolled my fenders lips. But for some strange reason, my 28x12.5 fits just fine... At the end of the day, I will probably run the 275/40 or 35.
Thanks.
Now: Boost...
post #15 of 27 (permalink) Old Jun 27th, 07, 10:48 AM
Brad
My problem I want to run a taller tire and a 35 is too low pro for me, and CA streets and billet wheels don't mix well, have bent to many.... Are you not looking to roll the fenderwell? If not a 275 will be perfect. I already rolled mine and on a 9.5 I think a 285/40 would fit nicely, plus I am aiming to get little to no body roll back there....
Muscle Car Car Club
whytry is offline
Pittsburgh World of Wheels pics 69camarojoe Bench Racing 4 Jan 23rd, 07 08:27 PM
Any pics of Wheels Vintiques 62's ENP Wheels & Tires 0 Dec 4th, 05 03:53 PM
The wheel fairy came!! HRE wheels pics inside... Teetoe_Jones Bench Racing 4 Sep 5th, 04 06:51 AM
18 inch wheels 1bad69ss Wheels & Tires 4 Mar 21st, 04 09:13 AM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
