10.5 slick on 8 inch rim????? - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 2nd, 07, 08:57 AM Thread Starter
Eric
Will it work or not???
Eric Bowling
2008 Ohio Crankshaft No Box Nationals Winner
1969 Camaro
406 sbc
Edelbrock Performer RPM Aluminum Heads
400 turbo
5600 8 inch Coan Converter
Transbrake
4.56 12 bolt
750 Holley RaceonE85.com Carb
ericsz is offline
post #2 of 9 (permalink) Old Aug 2nd, 07, 09:55 AM
Re: 10.5 slick on 8 inch rim?????
Should be ok.
Follow the Mfg.'s instructions, usually only +/- 1" tread Vs. wheels widths.
68 Camaro~LSx ~all motor
post #3 of 9 (permalink) Old Aug 2nd, 07, 10:07 AM Thread Starter
Eric
I knew that, if that is the case then it wouldnt be ok then, 10 inches of tread width and only 8 inches of wheel. I just didnt know if anyone has tried it to see if the 10.5 was better than the 9 inch tire on the 8 inch wheel...
Eric Bowling
1969 Camaro
406 sbc
400 turbo
Transbrake
4.56 12 bolt
ericsz is offline
post #4 of 9 (permalink) Old Aug 2nd, 07, 10:08 AM
Harley
wiskeesour's Avatar
I have seen vehicles have alot of wall 'walk' (aka wiggle) when launching. BE CAREFUL.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #5 of 9 (permalink) Old Aug 2nd, 07, 11:42 AM
Ten inch slick will work on an 8 inch rim, but as said, you'll have to run enough air pressure to prevent sidewall flexing at the big end.
Also, with a smaller width rim than tire tread width, the slick will grow in diameter considerably, moreso than if slick was mounted on a 10 inch rim.
post #6 of 9 (permalink) Old Aug 2nd, 07, 10:38 PM
Sean
It will probably end up "crowning" in the middle from being tight on the rim, and you'll lose contact patch, you may be better with a 9" tire. I know guys running 9's on a 9" tire easily, are you having traction problems of some kind?
Sean
Franklin D. Roosevelt
68rs406 is offline
post #7 of 9 (permalink) Old Aug 3rd, 07, 04:09 AM
That's the term I was trying to remember - "crowning" Thanks, Sean!
post #8 of 9 (permalink) Old Aug 3rd, 07, 06:30 AM
.gearhead.'s Avatar
I have a 12.5" tire on an 8" wheel. Zero problems.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #9 of 9 (permalink) Old Aug 3rd, 07, 06:53 AM
10.5 x 28 - 15's work fine on an 8" rim at 13-16 psi depending on your chassis, weight, power level etc.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
