2" smaller rear tire - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 18th, 07, 10:25 AM Thread Starter
Josh
i have a 275/60/15 on a 15x8 wheel with no rubbing, but to me this is just to big of a tire i think, im geared 3:55 with a 4 speed and it still kinda has a low bottom end, and im thinking its because the 28" tall tire...im thinking of going to a 245/60 or a 255/60 or maybe even try a 275/50 ?
any idea how much more bottom end i could pick up on going down a inch or 2
ridinbikes247 is offline
post #2 of 6 (permalink) Old Aug 18th, 07, 12:12 PM
Re: 2" smaller rear tire
Josh,
I have 4.11 gears. I have a P235/60/R15 which is a 26.10" tall tire. I need more top end but I can empathize with your situation.
Try this tire size calculator http://www.1010tires.com/TireSizeCalculator.asp
and then this RPM calculator. Plug in your numbers on the BOTTOM box. http://www.csgnetwork.com/multirpmcalc.html
With P245/60R15 you should be fine. Just my 2 cents.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #3 of 6 (permalink) Old Aug 18th, 07, 01:09 PM
275/50/15 is a 26" tall tire .
68 Camaro~LSx ~all motor
post #4 of 6 (permalink) Old Aug 18th, 07, 02:37 PM
Use----------
MPH = (rpm x inches tire dia.)/(rearend gear ratio x 336)...
pdq67
post #5 of 6 (permalink) Old Aug 18th, 07, 05:41 PM Thread Starter
Josh
i meant like, would i feel a difference in power, not like speedometer and rppm change...just like if i went from a 28" tire to a 26" tire, if i could feel a difference in taking off
post #6 of 6 (permalink) Old Aug 19th, 07, 05:59 AM
Yes!!
Your car will act like you dropped down a gear!
Like from 3.07's to 3.31's or whatever you have to one size lower!!
And this usually causes traction problems..
pdq67
