help: best tire size for a '68 - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 23rd, 07, 06:33 PM Thread Starter
i have a 1968 SS Camaro with 15 x 7 chrome rally rims. please tell me the best front and rear tires size? should i use the same size all around or 245/60R/15 back and 225/60R/15 front or some other sizes. thanks.
FLJETS is offline
post #2 of 12 (permalink) Old Aug 23rd, 07, 06:56 PM
Josh
Re: help: best tire size for a '68
i think what you suggested would look really good, maybe even a 255/60/15 on the rear, but it might be to big , if i could do my car over again i would want to do the plain ralleys and 245's in the back and 225's in the front....or if i had a milliondollars i would like a nice set of 17's or 18's with coil overs and Etc.
ridinbikes247 is offline
post #3 of 12 (permalink) Old Aug 23rd, 07, 08:38 PM
AJ
You can fit a 255 with the right b/s, I wouldn't do it on a 7" rim though a 255 on a 8" wheel is as wide as I would take it before the tire looks like it "bubbles" over the wheel. 245 would look good on that wheel, I see that width alot on Camaros with rally wheels.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 12 (permalink) Old Aug 23rd, 07, 08:58 PM
With 15x7 all around. The 245/60/15 rear and 225/60/15 front will look good. I have 255/60/15 on 15x8 rally on rear and 225/60/15 on 15x7 rally on front. with 4 inch b.s. and no rubbing. All tires and rims are within the fender wells.http://gerrygroeber.spaces.live.com/...&_c=PhotoAlbum
67for/me
67for/me is offline
post #5 of 12 (permalink) Old Aug 24th, 07, 04:32 AM
67 Convertible's Avatar
I have 15x7 Crager SS's on my '67. 245-60-15 rear, 215-60-15 front. Looks real good to me, no rubbing issues at all.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #6 of 12 (permalink) Old Aug 24th, 07, 01:55 PM
Strick
I have 15x9 on the rear of mine with 255 60R15's. The rims are deep dish I do not know the back spacing- they came with the car. The tires rub if there is a harsh bump.
Strick
Strick is offline
post #7 of 12 (permalink) Old Aug 27th, 07, 08:28 AM Thread Starter
my rims are 15X8, do you think it would look good with 225/60/15 on all 4. most companies have a very limited supply of 15 inch tires. thanks david
FLJETS is offline
post #8 of 12 (permalink) Old Aug 29th, 07, 09:14 AM
Thumbs up Re: help: best tire size for a '68
i have a 68- my aim was to fill the wells as much as possible -and use a wide tire in the back- the result was exactly what i looked for- accomplished by using 235/60 for the front and 255/60 rear. the only difference is with the rear rim size- i have 15x7 front and 15x8 rear- so find out what people think of using the 255 on 7" rim.
pics to follow.
ets68camaro is offline
post #9 of 12 (permalink) Old Aug 29th, 07, 10:55 PM
I have a 68 and have on the rear 295/50-15 on the original 7" rims doesn't rub and fills the wheel well on the Frt I run a 215/60. They say you can't run this tire size on a 7" rim I have had them on for 8 years but only 4000 mi. and a few runs at strip at 126 with no issues
TRS68Z is offline
post #10 of 12 (permalink) Old Aug 31st, 07, 11:36 AM
Bill
You may want to consider going 215 vs. 225 up front. I have the 225/60s and the drivers side very slightly rubs the fender when turning all the way to the left. It's odd though cause it only did that after I swapped spindles while converting to discs. I guess this changed geometry slightly. My opinion is that a Camaro needs something much wider than 225/60 in the rear but if your looking for a more stock appearance then would be fine.
68RS-SS is offline
post #11 of 12 (permalink) Old Sep 3rd, 07, 08:29 PM
James
Send a message via AIM to RATified68ss
275's out back on 15x7's w/ 1-1/4" drop, 235's up front w/ global west small block springs in a big block car. The fronts rub on the outside on every bump. No problems on the rear. I need to switch the fronts to 215's probably.
http://www.dark-earth.net/images/WCG...mp0907-023.jpg
http://www.dark-earth.net/images/WCG...mp0907-024.jpg
360 CVC- "Highway" is a way or place of whatever nature, publicly maintained and open to the use of the public for purposes of vehicular travel. Highway includes street.
RATified68ss is offline
post #12 of 12 (permalink) Old Sep 5th, 07, 07:18 AM
I have BFG 25560R15's on the rear mounted on 15x7 Torque Thrust II's with no rubbing plus no air shocks. The front has 21560R15 BFG's on the same wheel.
Roadman is offline
