Ford 9 inch and tire size - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 27th, 07, 07:44 PM Thread Starter
Rick
I have a 69 Camaro that has a Ford 9 inch rear, leaf spring setup. The rear was there when I bought the car. The car has 15x8 Ralleys on the rear with 255/60/15's on it. After removing the slapper bars/etc that was also on the car when I bought it, I am now getting some tire rub when I hit bumps.
I was told that if I swap the rear tires and put 235/60/15's on it, I could still use the 15x8 Ralleys and that the 235 would pull the tire inside the fender far enough where I wouldn't have any more tire rub.
Do any of you know if this is the way to go? I'd prefer to have a Chevy rear under the car, but it's not in the budget at the moment. Do I need to change to 15x7's on the rear? Is the Ford 9 wider than a Chevy 12 or 10 bolt? Suggestions would be appreciated.
Also, if anyone living in the Atlanta area would like to swap a Chevy 8.5 or 12 bolt for a Ford 9 with two third members, I might be interested. The third member in the car is a 3.50, the one I just took out is a nodular iron 4.10.
Thanks,
Rick
duskblue69 is offline
post #2 of 2 (permalink) Old Aug 27th, 07, 07:46 PM Thread Starter
Rick
Re: Ford 9 inch and tire size
Also, the tire rub is toward the outside of the fender.
Rick
