Fronts - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 1st, 07, 07:54 AM Thread Starter
Fronts
I bought M/T ET Streets for my 67 recently. They are on a Weld Draglite 15X8 rim.
On the front, I have Weld's that are 15X6 with a M/S rated radial.
I'm looking for suggestions of what to run up front for tires. Should I run a front radial or bias ply?
Is there a tire that is suggested to run when you run ET Streets on the rear?
mkpatrick is offline
post #2 of 4 (permalink) Old Sep 2nd, 07, 08:47 AM
Re: Fronts
Running with less unsprung weight is good, especially up front. Most run a 15X4 wheel with either a Moroso DS2 or a VW tire, 165R15.
The Moroso tire is off-road only use as the radial can be used on the street. Radials in the rear, radials up front, if street driven.
post #3 of 4 (permalink) Old Sep 2nd, 07, 11:28 AM
Re: Fronts
Use caution if you run VW tires up front... they're rated to ?? 85?? mph.
I run bias ply's in the back and radials up front. It's not recomended but there's a lot of us that do it. MT does make a street bias tire that would be a better solution.
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old Sep 3rd, 07, 12:49 PM Thread Starter
Re: Fronts
I think my wheel is a 15X6.
Can I put a more narrow tire on that?
