Do 255/60-15s Clear on 69 Front? - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 5th, 07, 03:20 PM Thread Starter
I've been running rallys (15x7 front, 15x8 rear) with 235/60-15s on the front and 275/60-15s on the rear and want to use 255s all the way around. Will the fronts clear? Thanks
jweb4747 is offline
post #2 of 11 (permalink) Old Sep 5th, 07, 03:42 PM
Tory
Camaros-n-Chevelles's Avatar
Re: Do 255/60-15s Clear on 69 Front?
I would not go any bigger than the 235s in the front. My 235s rubbed very slightly and I replaced them with 225 60 15s in the front and 255 60 15s in the rear.
Tory
Camaros-n-Chevelles is offline
post #3 of 11 (permalink) Old Sep 6th, 07, 09:14 PM
I gotta agree with CnC on this one...P235/60R15's will clear on most 1969s with a 15x7 wheel and 4.25" backspace on a 15x7 Rally Wheel. I have P235/60/R15 all the way around on my 1969.
FWIW, The only car I have ever owned which did not have the same size tires all the way around was the first car I ever bought (my original 1969 Camaro). I like having the same size all the way around with the same type of wheel. I can look for uneven wear in one spot of the tire and then rotate the tires and find out if they are wearing evenly. My friends still can't believe my wife got over 80k miles on the tires on her mini-van over 5 year period. I have 75k miles on my tires over 6 years on my Explorer as the original ones were warranty replacement's in 2001.
When this 1969 gets done right and gets done the SOUTH SIDE way then I will put bigger tires in the back to get it to hook up until then, ho hum...
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #4 of 11 (permalink) Old Sep 16th, 07, 01:43 PM
Johnny
Why would you want to put 255's on the front?? that would be kinda crazy huge
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #5 of 11 (permalink) Old Sep 16th, 07, 02:03 PM
madmax87's Avatar
When I first got my Z back in 2000 it had 255/60 on a 15X7 ralley on the front and a 255/60 on a 15X8 ralley in the back. The previous owner had rolled the front fender extentions and the rear quarters top. It's just too big of a tire IMO. They would also hit when going up the drive. I'm now running a 215/65 in the front and 255/60 in the rear. Here's a pic of before and after. Usually I'm running Cragars but for some shows I run the ralleys.
With 255 all the way around
With 215 in front, 255 in rear
With Cragars 215 front, 255 rear
madmax87 is offline
post #6 of 11 (permalink) Old Sep 16th, 07, 04:17 PM Thread Starter
I asked about this because I was buying new tires and wanted the same size x4. I ended up with 4 225/60-15s and they're OK except I need to replace the rear 8" ralleys with 7s. I sorta wanted to use 235s on the front and 255s on the rear but choices are getting slim for 15 inch tires and the tires I wanted didn't offer those sizes in the same model. Oh well...guess I'll wait for these to wear out. It kinda looks neat to see it in stock form after all those years of running 275s on the rear.
jweb4747 is offline
post #7 of 11 (permalink) Old Sep 17th, 07, 08:54 AM
Rick
My reason for bigger tires in the front is braking!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #8 of 11 (permalink) Old Sep 17th, 07, 11:41 AM
Johnny
255's on the back is great but stick with your 235's on front. The 255's on front will cause all kinds of rubbing.
johnny67 is offline
post #9 of 11 (permalink) Old Sep 21st, 07, 08:28 AM Thread Starter
Thanks for all the help (except one) as I have made the decision to go with STOCK 225/60-15s all the way around. I must say it's a little refreshing after all those years of running 235s and 275s. Road noise, handling, ride height and other things have improved dramatically. Probably won't do it again but it's a nice change...for now. Thanks again.
jweb4747 is offline
post #10 of 11 (permalink) Old Sep 21st, 07, 08:47 AM
Tim
Havin' Fun's Avatar
Which brand tire did you end up with?
Havin' Fun is offline
post #11 of 11 (permalink) Old Sep 21st, 07, 09:36 AM Thread Starter
Kumho Ecsta ASX
This is my third set and I couldn't be more pleased.
jweb4747 is offline
