Will both these fit? - Team Camaro Tech
post #1 of 12 (permalink) Old Sep 6th, 07, 03:00 PM Thread Starter
Danny
Question Will both these fit?
Front wheels 15x7 with 3.750 backspace. Rear wheels 15x8 wtih 3.875 backspace. Stock suspension front and rear. No tubs.
#1: P225/70R15 27.4 diameter front and P255/70R15 29.1 diameter rear.
# 2: P235/60R15 26.1 diameter front and P255/60R15 27.0 diameter rear.
From my research I think either front will fit but I am not sure about the rears with that backspacing.
Many thanks,
Danny Glasgow
Friendsville, TN
Mrs. G's quote: "Better a younger car than a younger woman."
RSDannyG is offline
post #2 of 12 (permalink) Old Sep 6th, 07, 09:25 PM
Re: Will both these fit?
I would recommend option #2.
P195/75/R14 is also 26.1" OD....This was the OEM size in the bias to radial equivalent and then radial only on many Camaro's...P195/75/R14 also came on Regals, Ventura's, Nova's & Cutlass. P235/60/R15 is as you know 26.10 in OD.
The 15x7 4.25" backspacing fits the rears nicely. You gain an inch in width but lose some in backspacing. I still like option 2 better as it gives you a wider aspect ration which will improve your cornering, handling & dry traction.
FWIW, the P225/70R15 was OE on Z28's in the late 1970's Trans AM's the Corvette & many Police Cars used that size as well back in the day with a Good Year Eagle GT which later became the GT +4
Still like option #2
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #3 of 12 (permalink) Old Sep 16th, 07, 01:50 PM
Johnny
It all depends how much space you are comfortable with from the top of the tire to the top of the wheel well opening.
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #4 of 12 (permalink) Old Sep 16th, 07, 07:14 PM
There's no way I'd put a 27" tall tire on the front. It's gonna hit something. Try gor under 26, even as little as 25. (mine are 23 1/2"!)
A 215-65-15 is a good choice, as is a 225-60-15.
On a 7" rim, you want 4" BS in front. 3.75" may be ok with a short tire. Mine are 3 7/8" The tires are out a lil, but don't scrape cause they are so short, and because I've done other mods to the front suspension that help.
On the back, a 29" tire is barely gonna fit in there, it's just too tall, will probalby scrape the rocker in the front. The 255-60-15 is perfect though.
Again, not enough backspace. With an 8" rim, 4 1/2" of backspace will center the tire in the available space.
*** note I don't know the year of your car. What I say is true of 67 & 68's, I'm no expect on 69's, but what I've read hear holds it true as well.
post #5 of 12 (permalink) Old Sep 17th, 07, 11:37 AM
Johnny
The 68 and 69 Z28 camaro's had 26.73" overall diameter on front and back according to the Kelsey tire site.http://www.kelseytire.com/pages/preformancetires.html try a 215/70 R15" BFG tire on front and 235/70 R15 on back for a stock look.
johnny67 is offline
post #6 of 12 (permalink) Old Sep 17th, 07, 07:43 PM Thread Starter
Danny
Unhappy Re: Will both these fit?
Jim,
I was feeling pretty good about the 60 series tires til your post. The wheels I want to use are Keystone Klassics and I can't get a 4.5 backspace for the rears. I rechecked the specs on the rears with 3.875 backspace. They show a negative .63 inch offset so am I correct in that this will add .63" to the backspace bringing it to 4.505? If so, then this wheel should work.
Thanks,
Danny Glasgow
Friendsville, TN
RSDannyG is offline
post #7 of 12 (permalink) Old Sep 17th, 07, 07:49 PM
I really wish they still used "offset" simple, elegant and to the point.
"backspace" is a real crappy term cause it's dependant on the rim width.
Yes, negative offset moves the tire into the car.
Half an 8" rim is 4" plus .63 = a schosh more than 4 5/8 BACKSPACE.
Yes, those wheels will fit and will hold a 255 tire nicely.
post #8 of 12 (permalink) Old Sep 17th, 07, 07:50 PM
so where the heck does the 3.875 come in?
post #9 of 12 (permalink) Old Sep 17th, 07, 08:54 PM Thread Starter
Danny
Cool Re: Will both these fit?
Jim,
I got the specs from Summit's site which says the following:
Brand: Cragar
Product Line: Cragar Keystone Klassic Wheels
Part Type: Wheels
Rim Diameter (in): 15 in.
Rim Width (in): 8.00 in.
Backspacing (in): 3.875 in.
Offset (mm): -16.00mm
Wheel Material: Steel
Wheel Finish: Chrome
I assumed from this that you would add the offset to backspacing.
Danny Glasgow
Friendsville, TN
RSDannyG is offline
post #10 of 12 (permalink) Old Sep 18th, 07, 06:10 AM Thread Starter
Danny
Question Re: Will both these fit?
Hey Jim,
I looked at this again this morning and am now confused. If you take an 8' wheel with the centerline at 4" then subtract .63 for negative offset then don't you now have a backspace of 3.37" and not 3.875 as shown in the specs? Am I missing something?
Thanks,
Danny Glasgow
Friendsville, TN
RSDannyG is offline
post #11 of 12 (permalink) Old Sep 18th, 07, 06:54 AM
I'm missing it too. Maybe call keystone and see what the deal is?
Make sure you are armed with the keystone part # from summit's site when you make the call.
post #12 of 12 (permalink) Old Sep 19th, 07, 03:28 PM Thread Starter
Danny
Jim,
I sent an e-mail to Cragar inquiring about this offset issue. Here is the response:
"NO NO NO when measuring backspacing it is based on the overall width of the rim outter most edge to outter most edge, when mesuring offset it is from bead seat to bead seat."
I still didn't get it. I sent another e-mail asking if I am correct in thinking the offset as shown in their specs does not have any bearing on the backspace and asked them to confirm the backspacing on this particular wheel. No reply yet.
Danny Glasgow
Friendsville, TN
RSDannyG is offline
