68 Wheel rub - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 10th, 07, 12:35 PM Thread Starter
68 Wheel rub
Front tires are rubbing on turns at the back of the fender well when turning. Have 15x7 centerline wheels with 3 5/16 backspacing. Just put moog 6308 springs on and thought that would bring it up enough to clear. Then someone told me I needed a smaller tire. Had 235 x 60R on, went to a 215 x 70R and they are rubbing just as bad. Is there something else I need to be looking at. When visually looking at the frontend it seems there is plenty of room all around for these not to rub. Car has front disc brake kit on it and front end redone (new ball joints, tie rod ends...etc) can something be screwed up there?
68mutt is offline
post #2 of 11 (permalink) Old Sep 10th, 07, 12:46 PM
Ryan
Re: 68 Wheel rub
Do you have any idea where you're rubbing at?
Rhino is offline
post #3 of 11 (permalink) Old Sep 10th, 07, 12:52 PM Thread Starter
Re: 68 Wheel rub
It's right at the back and bottom of the front wheel well, there is a bolt at the bottom of the wheel well and it is rubbing there. When you turn either way and both tires are doing it.
68mutt is offline
post #4 of 11 (permalink) Old Sep 10th, 07, 01:36 PM
Re: 68 Wheel rub
Some guys replace those bolts with button head allen bolts.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #5 of 11 (permalink) Old Sep 10th, 07, 01:39 PM Thread Starter
Re: 68 Wheel rub
Definately thought about grinding the bolt heads down, but turning and hitting an incline, it's hitting more than just the bolt head.
68mutt is offline
post #6 of 11 (permalink) Old Sep 10th, 07, 05:43 PM
Tory
Camaros-n-Chevelles's Avatar
Re: 68 Wheel rub
You need more backspacing on your rims. My rims are 15x7s with 4.25 inches of backspace. I also converted to front disc brakes which push out the tires slightly. I have 225 60R 15 BF Goodrich Radial TA Tires on the front with no rubbing issues at all.
Hope this helps.
Tory
Camaros-n-Chevelles is offline
post #7 of 11 (permalink) Old Sep 10th, 07, 06:48 PM
Steve A.
flat350's Avatar
Send a message via AIM to flat350
Re: 68 Wheel rub
If you go to this web site WWW1010tires.com they have a tire size calculator you can use . It says a 235/60/R15 tire is 26.10" in dia. and a 215/70/R15 tire is 26.85" in dia. so it seems you put a larger tire on when you went to the 70 series tire , that may be why it still rubs . If you went to a 215/60/R15 tire it's 25.15" in dia. which would give you a inch less in dia. I have the same problem on my 68 with 245/60/R15's and I think 215's will fix it on mine.
68 work in progress , but I can drive it now - O5D build - 712 trim - 02 color
Think it was a 396 , 4 spd. - now in primer , 350 , 4 spd. , lots of new body and mech. parts
flat350 is offline
post #8 of 11 (permalink) Old Sep 11th, 07, 06:41 AM Thread Starter
Re: 68 Wheel rub
Yep, sounds like it is a larger tire. I want to avoid buying new wheels, had these for a while and don't think I can swap. That 215/60/R15 sounds good. Will look for those and try it. Thanks for the info.
68mutt is offline
post #9 of 11 (permalink) Old Sep 11th, 07, 04:53 PM
Re: 68 Wheel rub
You really need 7" wide rims that have a stock, front spacing of 2.25" to cure this!!
My old Fenton 14" x 7" w/ 3.5" b/s would rub my front wheel well lip chrome strips at full droop so you need to get your width w/ a deeper back spacing.
pdq67
post #10 of 11 (permalink) Old Sep 11th, 07, 05:05 PM
bill
Re: 68 Wheel rub
good luck on finding bf goodrich tire size. p215/60r/15 they not available on national backorder. i went with cooper cobra radial g/t the p215/60r/15 with a 8 inch rim did fine no tire rubbing even with 5 people in car and heavy turns.stock front end also.
hereitis67 is offline
post #11 of 11 (permalink) Old Sep 18th, 07, 06:47 AM Thread Starter
Re: 68 Wheel rub
215/15/60R's did it. No more rubbing, thanks for all the info. Did have to order from manufacturer for the Goodyear Road Hugger GT's, only thing, had to do black wall. They don't make them with the white raised letter anymore.
68mutt is offline
