A good drag slick for 69 - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 10th, 07, 08:30 PM Thread Starter
i have a 69 with 15 x 7 steel wheels. what would be the best drag slick i can use for these. i can only get down to a 2.00 60ft time. i have stock monos and and currently running 265/50r 15 in the rear. i was looking and 26 10 15 M/T but im not sure. ive got a sbc 350 w 2400 stall at the line with 3.73 in the rear. ET is 12.8 at 108 with the street tires. how much time you guys think it would shave off my 1/4 mile time with some good traction?
bryce is offline
post #2 of 5 (permalink) Old Sep 11th, 07, 01:50 PM
Re: A good drag slick for 69
I would recomend drag radials. Mickey Thompsons to be exact.
3753R P275/50R15 26 X 11.50R15 31 R2 7.5-9.5 8.5 11.3 10.4 26.1 82
3756R P255/60R15 27 X 10.50R15 31 R2 7.0-9.0 8.0 10.7 8.8 27.1 85
3754R P275/60R15 28 X 11.50R15 33 R2 7.5-9.5 8.0 11.0 9.5 28.0 87
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Sep 11th, 07, 10:41 PM
Sean
Ditto
They definately work for me.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 5 (permalink) Old Sep 12th, 07, 03:58 AM
With 7 inch wide wheels, I personally wouldn't go over a 9 inch slick. Sidewall will be rolled in too much from 10 inch wide tread to a 7 inch wide rim. Tire will gain alot of ballooning at the top end, meaning grow in diameter.
Just my thoughts. Talk with a slick salesman. I'd go with a 26X9 slick. But then I'm not tire salesman either.
post #5 of 5 (permalink) Old Sep 12th, 07, 12:35 PM Thread Starter
If an 8" wide rim would be better i have no problem buying a pair. If any one knows where i can get a plain ol' 15x8 steel wheel that would be appreciated. should i stay with a 26" diameter or try to go taller?
bryce is offline
