Wheel wobble - Team Camaro Tech
post #1 of 15 (permalink) Old Sep 19th, 07, 09:53 PM Thread Starter
Strick
Wheel wobble
This is weird. Many of you know I am in the final stages of getting my car on the road. What many of you don't know is that one year ago (almost to the day) I drove my '67 6-cyl/PG Camaro from Nashville TN, where I purchased it, to Reno NV. The car ran GREAT!
I was just getting ready to take my car down to get the exhaust put on, but as per the Summit flyer, I needed to warm the tranny up and check the tranny fliud level. I put the car on stands, start the car and let it warm up thoroughly, put it in reverse to get the tranny fluid warm. So when I get out of the car to check the fluid I notice the drivers side rear tire is wobbling. I freak out! I figure something is wrong with the NEW 9" I assembled a couple of months back. I swap the rims from side to side, and guess what? The rim has a wobble (BAD WOBBLE). I drove the car from TN like this = NO WAY.
What in the world would cause a wobble like this?
Strick
Strick is offline
post #2 of 15 (permalink) Old Sep 19th, 07, 09:59 PM
Re: Wheel wobble
a bent wheel....
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #3 of 15 (permalink) Old Sep 20th, 07, 01:57 AM
parkbrau's Avatar
Re: Wheel wobble
Curbs. Blunt force trauma to the wheel.
parkbrau is offline
post #4 of 15 (permalink) Old Sep 20th, 07, 07:21 AM Thread Starter
Strick
Re: Wheel wobble
I drove the car 2300 miles and never noticed a wobble like this?
I don't think so! This is just plain strange!
Also, there is no uneven tread wear.
Strick
Strick is offline
post #5 of 15 (permalink) Old Sep 20th, 07, 01:24 PM
Re: Wheel wobble
It's the wheel and NOT the tire ? Correct ?
Pull the wheel and check the runout on the axel and while you're there check the wheel fitment on center flange Vs. the wheel center.
68 Camaro~LSx ~all motor
post #6 of 15 (permalink) Old Sep 20th, 07, 02:36 PM Thread Starter
Strick
Re: Wheel wobble
Doug it happens on whatever side I put the wheel on, so it is definitely tire/wheel specific. I am taking the Cragars off of my '56 and using them until I either get another A/R Rally Chrome or upgrade to another wheel.
What a pain!
Oh, but I am going to take this wheel/tire to a tire shop for inspection.
Strick
Strick is offline
post #7 of 15 (permalink) Old Sep 21st, 07, 05:02 AM
Re: Wheel wobble
I have seen tires seperate the tread from the tire and wobble. As it spins look at only the wheel itself. Mostly steel radials will do it from a puncture that let water in and rusted inside the tire. Just a thought.
blue ss is offline
post #8 of 15 (permalink) Old Sep 22nd, 07, 10:31 AM
Re: Wheel wobble
Or a broken belt... thats why I asked.
Is it the tire or the rim ?
post #9 of 15 (permalink) Old Sep 23rd, 07, 01:16 PM Thread Starter
Strick
Re: Wheel wobble
Well, I think I have discovered the answer to my wheel wobble, but only after putting my Cragar S/S on the car from my '56.
The calipers are not clearing the wheels properly? The wheels are seem snug against them, but I don't hear any scraping noise-??
Couple of questions --> Can I space the wheels out? (using say a washer on each lug?)
Is it O.K. to space the wheel (safety wise)?
These are the rears and with the 8" Cragars on (255/60R15) I have plenty of room in the wheelwell.
Thanks guys!
Strick
Strick is offline
post #10 of 15 (permalink) Old Sep 23rd, 07, 01:38 PM
Re: Wheel wobble
If the wheels were hitting the calipers you'd know it instantly. You'd hear it and see grooves cut in the caliper and the wheel.
I'd take the wheel(s) to a tire shop and have them put it on their balance machine.
I suspect you have a bent wheel.
BPOS is offline
post #11 of 15 (permalink) Old Sep 23rd, 07, 06:12 PM Thread Starter
Strick
Re: Wheel wobble
Thanks Al!
I just got through driving the car for the first time just now = WOW! 500hp naturally aspirated is a RUSH!
Tomorrow muffler shop, and Tuesday alignment.
Strick
Strick is offline
post #12 of 15 (permalink) Old Sep 23rd, 07, 08:40 PM
Re: Wheel wobble
Im sure 500 HP is just as much fun when its forced...
400bird is offline
post #13 of 15 (permalink) Old Sep 27th, 07, 09:25 PM Thread Starter
Strick
Re: Wheel wobble
Painful update. I was a the tire shop today to get lower profile fronts and blackwall out the rears, and lo and behold, one rotor was cracked and the other was completly broken apart. The shop seemed to think the axle hole was to small. However, it seems the re-drilled lug holes, to accomodate a chevy bolt pattern on a ford rotor, were slightly mis-aligned. When the rotor was just floating on the axle (no wheel) they seemed fine, but when the wheel with torque was applied the got to the point on binding/cracking/breaking. I had to have the shop put the wheels on for my slow 8 mile drive home. Here is the cause of the wheel wobble:
This is what happens when you put Ford parts on a Chevy!!
Name:	bad rotors.jpg
Strick
Strick is offline
post #14 of 15 (permalink) Old Sep 28th, 07, 03:59 AM
Re: Wheel wobble
If the problem started with one wheel and it moved to the other wheel, I'd check the backside of the suspect wheel.
Or the tightening event of wheel to axle. Sixty-five ft./lbs., or the value from the manf of the wheel, total torque in three steps in a star pattern.
The rotor damage is the effect, not the cause. Just my thoughts.
You would think the wheel manf's would engrave the torque value onto the backside of the wheel for future reference to the owner/installer. I know extra work, more cost, less profit. I reckon the torque value is left to the stud size/thread count.
post #15 of 15 (permalink) Old Sep 28th, 07, 07:26 AM Thread Starter
Strick
Re: Wheel wobble
It is a rotor issue nothing else.
They are Ford Explorer rotors re-drilled to a standard Chevy 5 X 4.75 lug pattern. The 'kit' maker mis-drilled the rotors.
Strick
Strick is offline
