245/50-16s on the Front? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 26th, 07, 01:35 PM Thread Starter
The diameter of a 245/50-16 is exactly the same as the stock 225/60-15s on a 69. I know there's no problem using the 245/50-16s on the rear but, am wondering if they will clear on the front. Has anyone here tried these on the front? Thanks
jweb4747 is offline
post #2 of 8 (permalink) Old Sep 26th, 07, 03:23 PM
Re: 245/50-16s on the Front?
I have that size on the rear,
I test fit one on the from and it rubbed, but just barely and it was on a rim for the rear, so the backspacing was off
I think may have had problems with that big of a tire in the front, it can be done, just make sure you get your backspacing just right
400bird is offline
post #3 of 8 (permalink) Old Sep 26th, 07, 04:28 PM
On my 67 L30/M20, I did a 245x50x16 on a 4.5" BS with a 3/16" spacer (for the spokes to clear a new set of pads; after that I didnt need them)... and it would steer lock to lock without rubbing on a lowered chassis.
So... yeah. I think you can do it with the right BS.
Last edited by chicane67; Sep 26th, 07 at 08:31 PM. Reason: I left out some pretty important info... like an idiot.
chicane67 is offline
post #4 of 8 (permalink) Old Sep 26th, 07, 05:05 PM
T
What year car(s) are we talking about? There seems to be some differences between 67/68 and 69 in terms of tyre fitment.
That said, on my '69 I'm running 245/50R16 F & R on VWW 16x8" rims with 4.5" BS (no spacers). With "stock-style" front discs, ~4 deg of castor, ~-0.6 deg of camber and the top of the tire even with the wheelwell lip, I have about 1/2" clearance to the frame at full lock and no issues with the lip, but on the right side, the outer rear "corner" of the tyre just touches the rear of the wheelwell opening when turning right. I think with a little less castor, they'd be 100% fine.
Oddly enough, my 235/60R15 tyres on 15x7 repro rally wheels would touch the frame at steering lock. Different tyre brands have different profiles -- some may fit, some may not...
TMessick is offline
post #5 of 8 (permalink) Old Sep 27th, 07, 04:48 AM
Rick
I too have VWW V45 16x8 (4.5" BS) with 245/50-16 tires, and have no issues. My alignment is 4* caster, -.5* camber. I'm also using a 1/4" spacer thanks to Chicane67's evil influence on C4 13" front brakes.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #6 of 8 (permalink) Old Sep 27th, 07, 06:45 AM Thread Starter
69 Camaro...I ran 235/60-15s with no problems whatsoever. Of course the car has new BB springs in the front.
jweb4747 is offline
post #7 of 8 (permalink) Old Sep 27th, 07, 09:38 PM
Hey Rick... have you seen the new 18x9.5's with the 14.5" six pot AP's ??
post #8 of 8 (permalink) Old Sep 28th, 07, 04:26 AM
Rick
Credit limits being upped
Rick Dorion
RickD is offline
