Need wider Centerline Warrior front wheels. HELP - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 27th, 07, 10:42 AM Thread Starter
I just bought a 67 with 2" drop spindles. On the front is a 15X4 Centerline Warrior. I need to go wider up front because for street driving the donuts follow the grooves of the road too well. I need a wider contact patch.
It looks like my options are 15x7 with a 3 3/8 or 5" BS or 15x5.5 with 3 3/8" BS. I believe a 15x8 with 4.5" BS would be too big for a lowered car.
The fitment of the current 15x4 (BS ?) 26x7.5x15 diameter is perfect with no rubbing.
Will these backspaces fit ?
Ross Racing is offline
post #2 of 9 (permalink) Old Sep 27th, 07, 04:06 PM Thread Starter
Re: Need wider Centerline Warrior front wheels. HELP
They make a 15x7 with 5" BS. How would that fit on a car lowered 2"
post #3 of 9 (permalink) Old Sep 27th, 07, 04:29 PM
you may have a problem with tire clearance and the drop spindle. search drop spindle here and read this site:
http://www.pozziracing.com/first_gen...#37;20Spindles
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #4 of 9 (permalink) Old Sep 27th, 07, 04:31 PM
i've got 15x8's all around, and it handles better than any first gen I've driven.
W/ a lowered car its doubtful they'd fit.
m21man is offline
post #5 of 9 (permalink) Old Sep 27th, 07, 08:02 PM Thread Starter
What if I got the 15x7, 3.375" bs and used a spacer to get the total 4" BS
post #6 of 9 (permalink) Old Sep 27th, 07, 09:44 PM
you can't use a spacer to add bs. you can use a spacer to decrease bs.
eville is offline
post #7 of 9 (permalink) Old Sep 28th, 07, 02:12 PM Thread Starter
OK, so I could get the 15x7 with 5" BS and get a one inch spacer to get the 4" BS I need?
post #8 of 9 (permalink) Old Sep 28th, 07, 02:21 PM
if they will clear the drop spindles....
eville is offline
post #9 of 9 (permalink) Old Sep 28th, 07, 02:27 PM Thread Starter
Any idea what would work better.
1) 15x7 w/ 3 3/8 BS
2) 15x7 w/ 5" BS and 1 inch spacer
I could always buy one and try it
