any one make 17x10 rallys 1rst gen.?? - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 29th, 07, 03:54 PM Thread Starter
I have a mini tubbed 67 camaro conv.
dse says that 315 would fit best but here lies my problem..
I want the ralley wheel in steel and a 315/35/17 tire..(cant afford billet)
I can only find 17x9!! ( wheel vintique) for a custom offset
The tire calls for a 10.5-11 rim width
Can anyone help me????
skinnyboy67 is offline
post #2 of 11 (permalink) Old Sep 29th, 07, 07:14 PM
Ed
BigBlock1969RS's Avatar
Re: any one make 17x10 rallys 1rst gen.??
I am looking for the same thing.
BigBlock1969RS is offline
post #3 of 11 (permalink) Old Sep 29th, 07, 10:19 PM
i have the wheel vintiqes 17x9's on the rear. you could have stockton wheel widen them for you, but it will run into almost the same money for the billet. if you can afford those tires, then you can afford the billet! i'm only kidding... the steel is VERY heavy and hurt your performance anyway. i kinda wish i went with the billet...
guccieng is offline
post #4 of 11 (permalink) Old Sep 30th, 07, 07:19 AM Thread Starter
What size tire are you runnin on your green machine???
What would happen if I put a 315/35 on the 17x9??
would it even fit on the rim
Thansk for the info on Newton, I also called (Davids rally wheels)
They are on the web.
post #5 of 11 (permalink) Old Sep 30th, 07, 12:59 PM
ideally, i would have a 17x9 1/2 with 5 1/2 inch backspace, but they only make the 17x9 with 5 inch backspace, which i had to trim the fender lip for. the rubber is mt street radials at 275/40r17, which look ok, but i would perfer the look on the 9 1/2 inch width. i don't think anything bigger than a 275 would look good on a 9 inch width. too much bigger, like 315's might be downright unsafe.
guccieng is offline
post #6 of 11 (permalink) Old Sep 30th, 07, 08:13 PM Thread Starter
Thanks for the info...Im going to keep lookin for 17x10 because its the only thing I really want and can afford...And Im going to use 315/35/17!!!! (cheapest big tire I can find)
post #7 of 11 (permalink) Old Sep 30th, 07, 08:41 PM
good luck with the wide steel wheel you are not going to find it. I have been looking for 6 months for a 18x12 and it aint happening. Only option is a CUSTOM (read expensive) wheel
bucks69 is offline
post #8 of 11 (permalink) Old Oct 1st, 07, 04:51 PM Thread Starter
6 months!!!!!!!!!! what [email protected]#! I called 3 places for 17x10 just now and gave up...they are not out there.
Stockton wheel says they can custom make them but big$$$$$
post #9 of 11 (permalink) Old Oct 1st, 07, 04:58 PM
man and I so badly wanted to go with the stealthy look of steel too. I think it would be cool big steel rallye wheels would rock
bucks69 is offline
post #10 of 11 (permalink) Old Oct 1st, 07, 05:04 PM Thread Starter
Made up my mind 16x10..Now I just need the right tire 315/35/16???
really like the short side wall look..
post #11 of 11 (permalink) Old Oct 1st, 07, 06:13 PM
I don't think you can find a 315/35r16
the widest low profile 16" tire I have found is 255, cant even find a 275
So, I would keep looking for 17" rims
400bird is offline
