15x7 with 3 3/8" or 5" BS - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 1st, 07, 09:23 AM Thread Starter
I need new Centerline Warriors up front and can't decide if I should get the 3 3/8" BS or go with the 5" and use a spacer. I have read that I need 4" BS with a 15x7, especially with drop spindles.
Any disadvantages to running spacers?
1967 Camaro, Indigo blue, LS3 & 6L80 trans
2009 Cadillac CTSV Kooks headers with Corsas, intake, tune, 20" Forgeline ZX3p's 532 rwhp/517 rwtq
Ross Racing is offline
post #2 of 6 (permalink) Old Oct 1st, 07, 09:58 AM
Strick
Re: 15x7 with 3 3/8" or 5" BS
I just put 15 X 7 Cragar S/S in the front with 225/60R15 = NO ISSUES! The backspacing is 4 1/8 on the 7" wheels.
Strick
Strick is offline
post #3 of 6 (permalink) Old Oct 1st, 07, 10:04 AM Thread Starter
So do you think a 3.375" will work or will it be too close to the fender lip?
post #4 of 6 (permalink) Old Oct 1st, 07, 12:26 PM
Might work until you hit a dip and turn at the same time. Might be better off with 5" and spacers but that may require longer wheel studs. Most tracks want to see studs out the end of the nut.
TC # 349
zdld17 is offline
post #5 of 6 (permalink) Old Oct 1st, 07, 01:19 PM
Strick
If your front end is dropped as much as mine, then yes 3/4" will probably hit the wheel wells while turning sharp and hitting a bump.
Strick
Strick is offline
post #6 of 6 (permalink) Old Oct 1st, 07, 03:00 PM Thread Starter
Thanks for the info. I will order 1 wheel from Summit and get an idea of how it will work before mounting. If it doesn't I will return it. I will probably have to run a 215 or 225
