Will '99 Corvette Wheels fit my 69 SS - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 9th, 07, 09:39 AM Thread Starter
Jereme
Hello all,
I am looking at some low dollar light weight wheels for my 69SS that will accomodate big brakes (13", C5). I found an ad for a set of 99 Corvette wheels that are 17x8.5 in front and 18x9.5 in rear. In the stock back spacing configuration will these wheels work if I use the right rubber? If so, can you recommend some tire sizes?
Thanks for your input.
Jereme
1969 L78 SS396 (Engine Long Gone)
BBC 496, TKO600, Beautiful Stock 12 Bolt Posi (maybe the only stock thing left.
RedJet is offline
post #2 of 7 (permalink) Old Oct 9th, 07, 10:04 AM
DjD
DjD's Avatar
Re: Will '99 Corvette Wheels fit my 69 SS
Jereme - With those '99 Vette wheels the backspacing is going to be about 7" or so, more in the back a bit less in the front. You'll want about 5.5" bs on a 9.5" wheel out back and on a 8.5 up front you'll need 4.75" - 5" of bs. 8.5" wide on the front would really be pushing things too... You could use a wheel addapter but the cost of $200 -$300 might take the wind out of your sails, making low buck wheels not such a good deal.
...Dennis
DjD is offline
post #3 of 7 (permalink) Old Oct 9th, 07, 10:31 AM
the 99' wheels arent even that good looking IMO, although the 2000 and up think spoke c5 wheels are nice.
m21man is offline
post #4 of 7 (permalink) Old Oct 9th, 07, 10:45 AM Thread Starter
Jereme
Thanks for the feedback, even if it is not great news...
Regarding the 2000 and newer wheels -- would I have the same backspacing issues?
Thanks again.
Jereme
RedJet is offline
post #5 of 7 (permalink) Old Oct 9th, 07, 01:17 PM
DjD
DjD's Avatar
Yes... If you look around there are copies of the various Vette wheels being made with old car back spacing...
...Dennis
DjD is offline
post #6 of 7 (permalink) Old Oct 9th, 07, 05:05 PM Thread Starter
Jereme
Thanks! I looked at the sticky with the pics and have decided to increase my wheel budget and get some rolling stock that will fit for certain. I appreciate your help.
Jereme
RedJet is offline
post #7 of 7 (permalink) Old Oct 9th, 07, 06:13 PM
If you're sticking with 17-18's...when I bought mine the rule for a non-mini tubbed car was.
17x9.5 with 5.5 inches of BS REAR
17x8 with 5 inches of BS(drum) 5.25 inches of bs(disc) FRONT
Might want to use another quarter inch of Backspacing on the rear if you're running rear discs.
Good luck,
Don Z
68 Camaro - 540 HP AFR 412 CI, TH350 full manual, 3500 stall, 3.36 yukon gears/axles, 8.2" eaton posi, 17 inch Intro's. Jet black. Hotchkis sways, 3 in drop leafs/springs/bilsteins, G MOD, C5/4th gen brakes. 11.89 @ 119//2.01 60 ft
1968camaro123 is offline
