Tire and Wheel Size - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 13th, 07, 08:42 PM Thread Starter
Tire and Wheel Size
I have a 68 Camaro that I have Just installed a 525 - H/P ,383 in it and I have 15 x 8'' Ralleys with 275-60s on the rear,with 342's and a manual valve body auto, you can't even hold It on the road running 35mph in second gear.HOW WIDE A WHEEL AND THE BACK SPACING AND THE TIRE SIZE WOULD YOU HAVE TO RUN ,i DON'T WANT TO RUN THE 16 OR 17'' WHEELS i WAnt to run 15'' wheels.I don't to do any suspension work such as moving the springs inboard.Thanks Camaro BOB
bdcole_51 is offline
post #2 of 10 (permalink) Old Oct 13th, 07, 09:36 PM
Tory
Camaros-n-Chevelles's Avatar
Re: Tire and Wheel Size
15x7 or 15x8 Rally Rims with 4.25 inches of Backspace will work well with 255 60 15 Tires. 275s will rub.
On the front I recommend 225 60 15s on a 15x7 Rim with 4.25 inches of Backspace.
Tory
Camaros-n-Chevelles is offline
post #3 of 10 (permalink) Old Oct 14th, 07, 08:58 AM
Strick
Tory
The above advice will work. I have the Hotchkis TVS kit on my car with no coil spring isolators. Because I have a new set of Cragar S/S that I want to use the rubber off of, I am running 225/60R15 with 4 1/8" backspacing in the front = NO rubbing. I was running 255/60R15 on the rear with NO rubbing. Right now I have 235's on the back just to wear them out. I have 500hp in my 408" and the 235s are goinng fast!
Are you running 275/60R15 with NO rubbing? I don't think you can go much wider.
Strick
Strick is offline
post #4 of 10 (permalink) Old Oct 14th, 07, 01:53 PM
I have been running McCreays 285/60/15 SH's (sh = short) on 15 x 8's with 4.5" backspace and they do rub on hard corners and off camber bumps. I have the same issues at anything below 40.(3.73's here)
I borrowed a pair of 275/60/15's Mickey Thompson Drag Radials and put on my wheels... they did look a lot smaller (1.5" to be exact) and never cam close to rubbing. They are the ticket and will solve your problem. Well, mostly.
68 Camaro~LSx ~all motor
post #5 of 10 (permalink) Old Oct 26th, 07, 11:11 PM
.gearhead.'s Avatar
I run a few sets, including a set of 15x8 Weld Prostars with 4.5" backspacing and 28x12.5x15 Mickey Thompson ET Streets. I have Caltrac split mono leafs and Caltrac bars. Zero rubbing.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #6 of 10 (permalink) Old Oct 27th, 07, 02:56 PM
Jim, thats mini-tub'd right ?
My McCreay's rubbed on turns and off camber bumps
post #7 of 10 (permalink) Old Oct 28th, 07, 08:10 AM
.gearhead.'s Avatar
No mini-tubs. Stock wheel wells. Stock suspension. 15x8 wheel w/ 4.5" bs.
Now: Boost...
post #8 of 10 (permalink) Old Oct 28th, 07, 10:52 AM
Maybe my springs are walking ?
post #9 of 10 (permalink) Old Oct 28th, 07, 12:26 PM
.gearhead.'s Avatar
I believe the Caltrac mono leafs reduce unnecessary squat and sway and prevent tire rubbing.
Now: Boost...
post #10 of 10 (permalink) Old Oct 28th, 07, 02:01 PM
Just measured my tires off the car... actual 12" sidewall to sidewall.
They rubbed on the inner wheelwell, now cords are showing Now going with MT DR's at 275/haven't decided 50's or 60's/15.
3753R P275/50R15 26 X 11.50R15 31 R2 7.5-9.5 8.5 11.3 10.4 26.1 82
3756R P255/60R15 27 X 10.50R15 31 R2 7.0-9.0 8.0 10.7 8.8 27.1 85
3754R P275/60R15 28 X 11.50R15 33 R2 7.5-9.5 8.0 11.0 9.5 28.0 87
3757R P325/50R15 28 X 13.50R15 37 R2 9.0-12.0 10.0 13.1 11.6 28.0 87
