3 way split - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 20th, 07, 03:12 PM Thread Starter
3 way split
I'm still mulling over 3 options on some new wheels so my question is mostly weather the 3 I'm looking at will fit:
1. a set of torq thrust knock offs 17 x 8 4.5 bs with 235 45 zr17 & 17 x 9 5 bs with 275 40 zr17 $1140.00
2. polished tt II with kuhmos 17 x 7 4 bs 235 45 r17, 17 x 8 4,75 bs 255 45 r17 $1125.00
3. Old school selection tt II 15 x 7 4 bs 235 60 15, 15 x 8 4.5 bs 275 60 15 wheels $630, tires?
Will these combos all fit on a stock suspension 69? Thanks
paperman is offline
post #2 of 6 (permalink) Old Oct 23rd, 07, 11:06 AM
Bill
Send a message via Yahoo to Bill-E-BoB
Re: 3 way split
#2 would be my choice. They should fit...I just bought a similar set, smaller fronts & bigger rears though...my rears rub the exhaust pipe & I need to get new pipes bent, but other than that its a great fit. Mine are 275's instead of 255's, and on a 9.5" wide rim instead of 8" so I doubt you'll have that problem. See my post in the 'post your pics' sticky at the top of this forum to see it. Its purdy, but its a tight fit.
Oh, and my fronts are 225 instead of 235, but there's TONS of room around 'em still, so I don't think you'll have trouble with 235's.
Oh yes indeed...I'm as confused as you think I am.
Bill-E-BoB is offline
post #3 of 6 (permalink) Old Oct 23rd, 07, 11:57 AM Thread Starter
Re: 3 way split
Bill
Thanks, auction is closing soon so that helps alot. Are you coming to the Moultrie show in Nov?
paperman is offline
post #4 of 6 (permalink) Old Oct 23rd, 07, 05:53 PM
Bill
Re: 3 way split
Moultrie show? Where's that? If its local & I'm in town I'll try & make it. My car won't be there though...its not quite road ready...
post #5 of 6 (permalink) Old Oct 23rd, 07, 06:17 PM
Re: 3 way split
Forget #1 the rear backspace is too shallow - so is the front just not as bad. Do you really want 15s? If not the only choise is #2 which is still a compromise. My suggestion - wait save some more money and find something the fits within your budget.
Jack
JV69z/28rs is offline
post #6 of 6 (permalink) Old Oct 24th, 07, 03:49 AM Thread Starter
Re: 3 way split
Bill
Moutlrie Ga is the biggest car show and swap meet in Ga, its held 15 16 17 Nov. You can find everything there, it takes 2 days to see it all, go to map quest for directions.
paperman is offline
