Mini tubs with no Fram Mods. - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 21st, 07, 03:54 PM Thread Starter
Rico
Hi I plan on going with a G bar setup and I am considering doing a minitub.
Partially because I will need to Redo a shock tower repair anyway.
So my thought is just cut out the shock tower area (al La DSE instructions) and do the mini tub.
So Question is if I did a g bar and a mini tub can I still get some decent size tires under there without cutting into the frame?
XLexusTech is offline
post #2 of 4 (permalink) Old Oct 21st, 07, 03:59 PM
Re: Mini tubs with no Fram Mods.
I forget, but isn't the outside, "inner" wall right next to the rear S/F sheet metal??
So you will have to cut at least 1/2 out to create any sort of mini-tub width room??
pdq67
post #3 of 4 (permalink) Old Oct 21st, 07, 04:14 PM
Andy
It can be done! You will need to take a small slice out of the frame rail for clearence but not much. Check out this site. I refrenced it many times while doing my mini tubs found it very helpful.
http://www.lugnutz.com/67mtub.htm
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
post #4 of 4 (permalink) Old Oct 21st, 07, 04:16 PM
Cutting out the trunk floor behind the wheel well to the frame give you approximately 2" more tire room. So a 275 fits now and the added 2" (50.8mm) should get you approximately 325's now thats a tire
68 Camaro~LSx ~all motor
