Found these For Sale Will they fit my 67? - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 1st, 07, 06:43 AM Thread Starter
Rico
My 67 stock sub frame no minitubs may go with G bar and aftermarket front CTL Arms.
The r/t for sale below Will they fit my car?
I have a set of American Racing Torque Thrust II polished with Nitto 555 tires ONLY 250 MILES on them.
Details: $1400.00
Rears: 18" x 10" 5.75" B.S. with Nitto 275/40/18 tires
Fronts: 17" x 8" 4.5" B.S. with Nitto 245/45/17 tires
all 5 on 4.75" bolt pattern
XLexusTech is offline
post #2 of 10 (permalink) Old Nov 1st, 07, 06:56 AM
keypilot's Avatar
Re: Found these For Sale Will they fit my 67?
rears wont fit. my 67 will take a 18x 9.5 w/ 4.75 bs max.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
post #3 of 10 (permalink) Old Nov 1st, 07, 08:07 AM Thread Starter
Rico
and what size tire?
post #4 of 10 (permalink) Old Nov 1st, 07, 08:49 AM
I question that backspace. 5.5" is considered the max backspace. As always, measure your own car.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #5 of 10 (permalink) Old Nov 1st, 07, 02:24 PM
6D9
Ron
Im running some 18x10's with 5.75bs on my 69.Tires are also 275/40/18's. I needed to trim the fender lips but other than that fit is perfect! My car has a 2" front/3" rear drop. Biggest problem I see is the fronts. If your car is low the 4.5" bs and 245's will most likely rub. My first set of front wheels were 4.75bs and it rubbed bad. I ended up with 5" bs fronts and it still rubs some with a passenger in the car.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #6 of 10 (permalink) Old Nov 1st, 07, 06:01 PM Thread Starter
Rico
I thought the7 & 8 quarters were the same and the 9 is further out quite a bit. Point being they might fit a 9 but not a 7?
post #7 of 10 (permalink) Old Nov 1st, 07, 10:56 PM
6D9
Ron
The 69's seem to have a bit more room but check out "streetfighter68's" car on Pro-touring.com. He has a 68 and is running 18x10's with 5.5" bs. Tires are even wider at 285/35/18.
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #8 of 10 (permalink) Old Nov 6th, 07, 03:29 PM
6D9
Ron
Here is the 68 I was talking about...........
http://homepage.mac.com/streetfytr/Menu1.html
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #9 of 10 (permalink) Old Nov 10th, 07, 04:51 PM
Tristan
Send a message via AIM to Mav68erick
That cars tubbed from the looks of it shocks are inboard a bit and it says it has DSE leaf springs, so prolly minitub kit as well
EDIT: maybe hes got the DSE springs and the shock mounts from them and springs inboard to be able to scoot the tire in more..
68 Camaro
I Hate Spotwelds
Mav68erick is offline
post #10 of 10 (permalink) Old Nov 15th, 07, 02:14 PM
6D9
Ron
That car is NOT tubbed. All stock with rolled lips. The shocks have been relocated though.
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
