What are the bigest tires I can fit on the 69 - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 9th, 07, 10:08 PM Thread Starter
I just got my calvert suspension in. I will be bolting my 12 bolt and suspension in this week end. The rear end is the stock width. The leaf springs are also going in the stock location. The only thing not stock about it is the suspension is going to lower the rear ride height an inch. I will be buying new wheels. I need to know with out tubing what is the biggest tire I can fit under the car and what offset am I going to need the wheels to be to accomplish this feet.
Wade
In todays world of technology, there are many ways to go fast. None of which are near as fun as a big block, carburetor, and a stick.
satanismymotor is offline
post #2 of 9 (permalink) Old Nov 10th, 07, 07:41 AM
Re: What are the bigest tires I can fit on the 69
17 inch wheel, 5.50 backspace, 9.5in width, 275/40 tire
As used on my 69 in the signature below
and
Brian Lewis is offline
post #3 of 9 (permalink) Old Nov 10th, 07, 07:56 AM
DjD
DjD's Avatar
I scooted this over here to the wheel and tire forum, look around here and you'll find tons of info.
...Dennis
DjD is offline
post #4 of 9 (permalink) Old Nov 10th, 07, 12:34 PM Thread Starter
I am wanting a drag wheel and tire combo. some 15 inch wheels. I don't know If should get 8 inch wide wheels or if I should get 10 inch wide wheels for the back. Can I stuff 28 x 10.5s on the back? Can I go wider on the back maybe with the right backspacing on wheels? These are the questions I need answered.
Thank you much
Now I must go work on the car
Wade
post #5 of 9 (permalink) Old Nov 10th, 07, 03:24 PM
15 inch wheel, 4.87 backspace, 8.5in width, 28X10.5 tire
and
post #6 of 9 (permalink) Old Nov 10th, 07, 05:18 PM
I have 275/50/15's thats almost a 12" wide tire and like 25.5" high cant imagine getting too much bigger on a stock wheel well
Tacoma Tom is offline
post #7 of 9 (permalink) Old Nov 10th, 07, 06:54 PM Thread Starter
This member has some meats under his 68. Not sure if he is tubbed.
http://www.youtube.com/watch?v=mUUGXBybYZw
post #8 of 9 (permalink) Old Nov 11th, 07, 08:16 AM
I previously ran the biggest you can fit, it requires rolling the outer fender lips and will have some slight rubbing if turning out of a parking lot or passengers in the rear, but drag racing its fine
Weld Racing Draglite Wheels
Part # : WLD-90-57346
15" x 7" 3.5" Backspace
Mickey Thompson Indy Profile H50-15
Model 1074
Size Equivalent - 295/50-15
and
post #9 of 9 (permalink) Old Nov 11th, 07, 02:39 PM
I got 275/50 15
on 10" TT-II w/ 4,75" BS
There is no way to fit bigger tires on my car with stock ride height and no tub work without them sticking out from under the fender.
Now I donīt know if there are much differances between the 69 Camaro and 68 Firebird like mine but I doubt there is room for more rubber.
Sticky tires donīt need to be all that big.
firebird400 is offline
