Any one buy rally's from Rallywheelman on Ebay? - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 11th, 07, 03:08 PM Thread Starter
Chad
$365 plus $85 shipping for 67 flat cap rally wheels....gets good reviews from buyers, but seems too good to be true...any one see these in person b4?
http://cgi.ebay.com/NEW-Corvette-Che...QQcmdZViewItem
67 RS "yes that is the factory color combo"
cgrady is offline
post #2 of 11 (permalink) Old Nov 11th, 07, 03:58 PM
Chris
Re: Any one buy rally's from Rallywheelman on Ebay?
I bought a set of rally wheel derby caps from him. They are nice reproductions and he shipped them out fast. Can't comment on the wheels only the caps. I never had any problems with him.
ck 2 is offline
post #3 of 11 (permalink) Old Nov 11th, 07, 06:45 PM
Kevin
While going through a short period of anguish on what wheels to buy recently, I cam across him on Ebay. I actually talked with him for a few minutes. Seemed more like a business guy than a car guy, but nice enough. My concern was back spacing, and he said he could get them custom for...I believe... $30 more per wheel. I never asked him about chrome layering, but that was my only concern. Hell, even if they chipped badly after two or three years, you could buy another set at that price and still come out OK. They look pretty decent to me.
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #4 of 11 (permalink) Old Nov 11th, 07, 09:13 PM Thread Starter
Chad
it says 4" for 15x7...and 4", 5", or 4.5" for 15x8....thk 4.5" for 15x8 is correct, right?
im also in anguish...i want Foose Legends but $269/per at Wheels for Less and not sure if want orig. look or 17" crome...damn i've changed my mind 100 times
cgrady is offline
post #5 of 11 (permalink) Old Nov 11th, 07, 10:07 PM
Timothy
You should have both. Get the ones you want the most first. Why wouldnt you want both? You should change wheels like you would a tie.
My 69 RS/SS 396 Project -
"I may be dumb but I aint stupid"
Microgiant is offline
post #6 of 11 (permalink) Old Nov 12th, 07, 06:13 AM
Lucky68's Avatar
I bought a set of rallys from this guy a couple of years ago. The brand he sells is wheel vintiques. They aren't a bad wheel but I have heard of people having problems with the wheel(s) being out of round. I didn't have a problem with mine and they balanced up nicely. They are multi lug wheels, so if you're cool with that, I'd go ahead and buy them. I bought 15x7 front w/4" BS and 15x8 w/4.5 BS. I used BFG T/A's 215/65-15 front and 255/60-15 rear. They fit perfect.
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
Lucky68 is offline
post #7 of 11 (permalink) Old Nov 12th, 07, 10:21 AM
Vince
David is an honest guy and a straight shooter....................no worries buying from him.
I've bought more then 1 set from him and the last set he gave me a smokin deal because I picked 'em up!
3forme is offline
post #8 of 11 (permalink) Old Nov 12th, 07, 10:28 AM Thread Starter
Chad
thx for the responses....sure seems like a good deal from what they cost from Summit or Jegs
cgrady is offline
post #9 of 11 (permalink) Old Nov 12th, 07, 10:35 AM
Eric
One thing to watch on some of the reproduction wheels is whether they are hub-centric or lug-centric. This means they are either centered by the center hole (hub-centric) which is better, or centered by the lug nuts (lug-centric) which can be a problem. All OEM wheels, that I'm aware of, are hub-centric.
ERIC
67 Convertible, 350CID, TKO600RR, 3.73 Eaton Posi
ept000 is offline
post #10 of 11 (permalink) Old Nov 12th, 07, 11:29 AM
It doesn't matter unless some State Safety Inspector catches that they aren't hub-centric and they are supposed to be.
It happened to me after I installed brand new radials on some 6" wide MOPAR rims on my '64 Ford Fairlane S/W to up-grade it and the SOB wouldn't pass me! So I went back home and got my wore-out stockwheels and tires and installed them in the lot and he passed me!!
Then I proceeded to re-install my new tires and wider rims and that was that!!
I NEVER went in the f-- place again after that! AND I drove that old car like that for years and years!!!!
So go figure!!
pdq67
post #11 of 11 (permalink) Old Nov 12th, 07, 11:55 AM
Eric
So go figure!!
pdq67
I only mention it because you hear about a lot of guys thinking they have a vibration or maybe a bent wheel, and it turns out they are running lug-centric wheels. I have seen them have a different run-out every time you tighten the lug nuts.
ERIC
ept000 is offline
