Tire size - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 23rd, 07, 06:34 AM Thread Starter
Bill
Tire size
I have a 67 RSSS with 14X6 ralley wheels and stock suspension. I would like to know what size radial tire would fit. I don't want to raise the car,but I would like bigger tires then the E70X14's I have now. I was thinking 205/60X14. UPDATE....I have a chance to get 4 14X7 ralley wheels with 235/60/14 tires 3 3/4 back space will they fit? What would be the best radial tire and size to use? Help.
Bill
zz3vette is offline
post #2 of 6 (permalink) Old Dec 19th, 07, 12:38 PM Thread Starter
Bill
Re: Tire size
Originally Posted by zz3vette View Post
I have a 67 RSSS with 14X6 ralley wheels and stock suspension. I would like to know what size radial tire would fit. I don't want to raise the car,but I would like bigger tires then the E70X14's I have now. What would be the best radial tire and size to use? Help.
Bill
It's been a month and no reply. I guess i'm not accepted. Thanks for nothing.
zz3vette is offline
post #3 of 6 (permalink) Old Dec 19th, 07, 01:12 PM
Joe
Re: Tire size
I have 225-70-14 on my 14x6 wheels. I think that's as big as you can go with 70's. Not sure about 60 series. What kind of look are you going for?
Stock? Big rear/small front?
Obviously if you can get those 14x7 rims you can go with bigger tires but then it gets trickier to know if there's enough room in the wheelwells.
Oh, and don't be offended by not getting a reply a month ago. From my experience here, you get a pretty quick response MOST of the time, but once in a while a post seems to fall through the cracks and you feel like nobody cares about your question. You did the right thing by just trying again.
Joe
'68 SS/RS 350
Never enough time... even less money.
gro51 is offline
post #4 of 6 (permalink) Old Dec 19th, 07, 01:13 PM
class67's Avatar
Re: Tire size
I wouldn't say that you are not accepted. Maybe others are not comfortable answering questions about 14" tire / wheel sizes in this forum, as the larger dia. wheels are most common these days. I would try posting again in the restoration forum (assuming that is what you are doing with your 67). Just trying to help!
67 Camaro RS
class67 is offline
post #5 of 6 (permalink) Old Dec 31st, 07, 03:45 PM
Re: Tire size
Bill
The original equipment tire size for that car, by most accounts, is 215/70/14, i.e. F70x14.
Presuming my car is typical, a 235/60/15 will indeed rub a bit at the extreme ends of the turning radius. With a 14" wheel, you might be alright. Hard to know if it's the width or the height without having somebody look while you turn the wheel to the stops at slow speed.
The height of the original wheel/tire would be 215mm (width) x 1.4 (double the aspect ratio), with that result divided by 25.4mm to get the "inch" equivalent. Add the wheel diameter, and the height for a 215/70/14 is 25.85".
The height of the 235/60/14 would thus be 25.1". So, height-wise, you should be fine. Width-wise, could be an issue, but you pays your money and you takes your chance.
nate haler is offline
post #6 of 6 (permalink) Old Jan 1st, 08, 08:38 PM
Re: Tire size
In my experiences over the years you can get more tire on the front of a 1969 vs a 1967or 1968. But you can get more tire on the back of a 1967 or 1968 than you can on the back of a 1969.
nate haler is correct. Both my first gens have been 1969's and I ran OE 14x6 Rally's with P245/60R14's & front drums on my first 1969. No issues! The 1969 I have now has 15x7 aftermarket Chrome Rally's with P235/60R15's with no issues. I know some guys who tried that on their 1968's & 1967's & they had to go doen 1-2 sizes up front regardless of engine size or a/c options.
HAPPY NEW YEAR!!!!!!
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
