need help ordering the right wheels - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 23rd, 07, 06:58 PM Thread Starter
I have tried to get in touch with Foose and their manufacturer to order the right wheels for my car but the referred me to my local dealer that doesn't have a clue. I want 17" foose nitrous 2 rims and want to put as big of rim and tire on the rear as possible (inside fender well). stock looking width on front. I have a 15x10 cragar ss on rear with 295 50 and they stick out about 3/4 of an inch. I also have 4 wheel disc brakes. I would like to run a 9.5 275 on rear but don't know what backspacing for front or rear to get. I was told these rims are made to order so i need to get it right. any help would be appreciated.
Anybody running setup like this? Pics?
68 zz502 is offline
post #2 of 5 (permalink) Old Nov 23rd, 07, 07:11 PM
Re: need help ordering the right wheels
Front 18x8 (BS 5) with 235/40-18
Rear 18x9.5 (BS 5.5) with 275/40-18
and
Brian Lewis is offline
post #3 of 5 (permalink) Old Nov 23rd, 07, 09:07 PM
Thumbs up Re: need help ordering the right wheels
68 zz502 you did say 17s but the sizes and back space will be the same (you may want to go with 45 series in the front). Some people go 4.75" back space in the front but 1/4" makes very little difference. Do a search on this there is hours of reading. The bottom line is all these cars are a little different including side to side so when you get to these max sizes you need to check before you order. If not you may get slight rubbing or worse. Try to test fit something close. Good luck.
Jack
JV69z/28rs is offline
post #4 of 5 (permalink) Old Nov 24th, 07, 04:52 PM Thread Starter
Thanks for the info.
I did a little measuring on my car and think (hope) I got it right but I will run it by you to see if it sounds right.
Using the straight edge on rim to hub measuring I got 4" BS inner and 6" bs outer on the wheel. I currently have 1.5" gap from inner tire to inner fender. Using this I was thinking 5.0" bs rim would be the right one with 1/2 " gap
inner fender to outer fender is 12.5" so 9.5 on a 275 or maybe 295 with slight mods. what do you guys think? or do you have any suggestions for other measurements.
68 zz502 is offline
post #5 of 5 (permalink) Old Nov 24th, 07, 06:57 PM
I run
Front: 17x8 (4.75" backspacing) - 5x4.75 pattern
Back: 17x9.5 (5.5" backspacing) - 5x4.75 pattern
Kumho ECSTA SPT
Front 235/45WR17 - $79
Rear 275/40WR17 - $107
I have no rubbing, but I do have my fender lips rolled. 295 would be a very very tight squeeze, I had 295s on my 15" rims before (Mickey Thompson) and they rubbed.
and
