275 on 15x8 rally? - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 15th, 07, 10:02 PM Thread Starter
275 on 15x8 rally?
Will that fit under my 68 coupe without rubbing, wheeltubs or narrowing the rear end?
tks68 is offline
post #2 of 10 (permalink) Old Dec 15th, 07, 10:31 PM
6D9
Ron
Re: 275 on 15x8 rally?
Im running 275/50/15's on 15x8's. Backspacing is right at 4.5". Its a tight fit but my car is LOW. If your car is not real low it will fit no problem.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #3 of 10 (permalink) Old Dec 16th, 07, 12:13 AM
Sean
Here's a pic of my car with that wheel/tire, it's a 275/60-15 drag radial on a 4.5 BS 15X8 ralley. You can see if it was real low it would be a problem since it's right under the lip, but mine actually sits too high right now, I am going to go about 1" lower in the rear and it has room for that, and a bit more up front when I redo my suspension this winter (it's running stock springs right now).
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 10 (permalink) Old Dec 16th, 07, 07:15 AM
Borrowed 275/60/15's on Weld Draglites 15 x 8's w/ 4.5" bs.
68 Camaro~LSx ~all motor
post #5 of 10 (permalink) Old Dec 16th, 07, 07:45 AM
.gearhead.'s Avatar
Yes it should fit with a 4.5" bs.
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
post #6 of 10 (permalink) Old Dec 16th, 07, 06:10 PM
Jody
Anyone using this tire and wheel combo with a 4.750" or 5" b.s. 15x8 wheel? I am helping a friend with his '67 Camaro. A 5" bs would work but, how much tire clearance and flex to the inner wheel wells should we allow for?
Jody Haag
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
JodysTransmissions is offline
post #7 of 10 (permalink) Old Dec 17th, 07, 01:49 PM
My car measured 6" from wheel mounting point to the inner wheelwell and 5" to the wheelwell lip.
post #8 of 10 (permalink) Old Dec 17th, 07, 03:34 PM
6D9
Ron
5" would be pushing it. My 275's with 4.5bs rub on the inside of the wheel well under cornering or going up curbs at an angle. With a 5" bs I would use a 255/60/15. That should fit perfect.
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #9 of 10 (permalink) Old Dec 17th, 07, 03:46 PM
I had 295 wide McCreary's on a 15X7 Rally from a mid-70's Monte Carlo on my 67 and it only rubbed on the inside of the fenderwell on the right side when i made sharp left turns.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline
post #10 of 10 (permalink) Old Dec 18th, 07, 08:39 PM
Jody
Thanks for the replies. We will do some more measuring and test fitting next week.
Jody Haag
610-413-8015
