Torque Thrust II rim damage/repair? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 17th, 07, 05:01 PM Thread Starter
Exclamation Torque Thrust II rim damage/repair?
About 2 months ago, I took tire to local shop due to corrosion around the bead. When he was taking tire off rim, it "popped" and cause a few gouges in the back of the rim which isn't all that big of a deal, but also cause on one the out most edge of rim.
He has been doing tires for years and said he has never seen one "pop" like this one.
It is a 16 inch rim and he says he will pay the cost of repairing or replace it.
I have seen in magazines in the past for repair of rims that are dented from curbs etc., but wouldn't you know that now that I need a number, I cannot find an ad. I have searched in so many magazines, I know that I am not crazy.
Can anyone recommend a company that will repair the rim as well as polish it?
I am in desperate need to get it fixed soon.
Before I know it, spring will be here! (Ok, wishful thinking...)
ratbikeharley is offline
post #2 of 9 (permalink) Old Dec 17th, 07, 05:31 PM
bill
Re: Torque Thrust II rim damage/repair?
i know a company in nj but than you got to ship it to them and back. with corrosion tho im not sure if it is worth it to fix it. tommorow ill get there number from work and pm you it.
hereitis67 is offline
post #3 of 9 (permalink) Old Dec 17th, 07, 05:48 PM
Kevin
You might also consider sending it to AR to be repaired. However, it will likely take about 6mths to ever get it back
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #4 of 9 (permalink) Old Dec 17th, 07, 06:22 PM
class67's Avatar
Try esajianwheels.com! he does really good work.
67 Camaro RS
class67 is offline
post #5 of 9 (permalink) Old Dec 17th, 07, 06:26 PM
try this place. http://www.fixrim.com/
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #6 of 9 (permalink) Old Dec 17th, 07, 06:29 PM
Jason
heard good things about these guys. they will be repairing a TT II for me soon.
http://www.sabssuperauto.com/
zeb596 is offline
post #7 of 9 (permalink) Old Dec 19th, 07, 03:53 PM Thread Starter
The rims don't really have a corrosion problem. They are like new and have a great shine. I would like to send them all out and get a high polished shine on them and get the one fixed or replaced if it isn't too much.
Thanks for the sites. I really appreciate your help guys!!!!!!
post #8 of 9 (permalink) Old Dec 19th, 07, 08:05 PM
Place here in PA does great work, you could probably email them pics and get an idea of what you're looking at.
http://www.wheelcollision.com/wccsvcs.html
Eric
Eric Kammerer is offline
post #9 of 9 (permalink) Old Dec 20th, 07, 07:06 AM
Rex
I run a tire store and had several redone do to people hitting curps, etc.....it cost about 100 bucks. I use a place in Dallas called Superior wheel...it takes about three days, but I am only 2 hours from them. How did he pop the inside and the outside? He should have gripped the rim from the lip, using protective booties. Did the mounting head cause the outter lip damage?
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
