Stock 69 Camaro will this fit 17*8 F 17*9.5 R - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 30th, 07, 07:03 AM Thread Starter
Hey guys I'm almost finished restoring my car after 5 long years. I've read a lot of post but I just want to confirm I'll be ok with this setup:
American Racing Thorque Thrust II
Front: 17x8 4.75 backspacing 245/45/17 tires
Rear: 17x9.5 5.5 backspacing 275/40/17 tires
Will I have any problems with this setup on my car, Stock Suspension. Thanks guys.
Manny
69 Camaro SS (90% complete)
72 Camaro RS (still needs restoration)
05 Z71 Silverado
wickdracer is offline
post #2 of 6 (permalink) Old Dec 30th, 07, 08:12 AM
Kevin
Re: Stock 69 Camaro will this fit 17*8 F 17*9.5 R
Even without it being lowered, you MIGHT experience rubbing on both front and back. Your back spacing is correct, but 245 is pushing it for the front (frame rub), and 275 can cause issues on either side in the rear. But...there are members who swear they fit theirs without an mods.
Most tire places will mount them and then change them if they don't fit. Give it a shot.
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #3 of 6 (permalink) Old Dec 30th, 07, 09:11 AM
Rex
run that same set up on mine. I am lowered 1" in the rear and two in the front. I get a small rub every now and then on the front when I turn into a parking lot with a deep gutter, on the rear the drivers side rubbed a little on the pinch weld for the inner/outer wheel well. I installed a small spacer and took a hammer and bent the wheel well inboard, no rubbing now.
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #4 of 6 (permalink) Old Dec 30th, 07, 05:51 PM
You have to remember that these cars are all a little different. Almost 40 years of age - replacement sheet metal - fatigue - abuse - all impact tire clearence when you get to maximum sizes. We're not trying to back out on you - just warn you what you MIGHT be up against. Good Luck.
Jack
JV69z/28rs is offline
post #5 of 6 (permalink) Old Dec 31st, 07, 03:58 PM
I've got that rear combo, never noticed any rub till I removed the tires and saw where they had barely rubbed the inner well, but not enough to go thru the bedliner material. And I drive the poop out of mine. I would go 235/45 on the front. My car has 3" drops on the rear.
yellowrallys is offline
post #6 of 6 (permalink) Old Dec 31st, 07, 04:26 PM
my rear fenderlips HAD to be rolled. otherwise, that combo works on mine.
guccieng is offline
