BFG Radial T/A's 215/60/15 - Team Camaro Tech
post #1 of 28 (permalink) Old Jan 3rd, 08, 07:39 AM Thread Starter
I am letting everyone know who has been waiting for the BFG TA 215/60/15 tire that has been on back order for the past 4+ months may still wait even longer.
I just got done talking with a rep from BFG that says they are still making that size tire but havent started production yet. And it may be a few more month before they do.
Here is BFG's phone 800-521-9796 if you would like to ask for additional information or let them know you have been waiting for the tire as well.
Maybe a few calls will get the production started faster.
I may use the 225/60/15 up front but not sure what fitment issues I may run into.
Edit:
I am putting them on the front of my 68 RS Convertible that I did the steering mod on. I am trying to use a smaller tire to have the steering steer a little easier.
68 RS Convertible
327-L30/TH350/12 Bolt 3.73
mike_russell is offline
post #2 of 28 (permalink) Old Jan 3rd, 08, 08:26 AM
Re: BFG Radial T/A's 215/60/15
They told me last May that they were going to start soon on that size...
Eric
Eric Kammerer is offline
post #3 of 28 (permalink) Old Jan 3rd, 08, 10:56 AM
I dont know what you are putting them on, but I have used 225 , 235 and now 245 on my 69. Sometimes, on a bump and turn, the front wheels may hit the headlamp bucket covers with the 245. No issues on rear.
TC # 349
zdld17 is offline
post #4 of 28 (permalink) Old Jan 8th, 08, 05:37 AM
Doug
Wow I bought a set of BFG 215/60/15 last year at a tire shop that had them in stock and just sold them for $50 each so I could go with the Goodyear polyglas tires. I wish I knew you guys were looking.
Hope you get them soon.
Doug
Mr. Super Sport is offline
post #5 of 28 (permalink) Old Jan 8th, 08, 07:15 AM
Pat
I run 225's on the front of my 67 with no problem.There is a place here in Nashville that always seems to have the BFG 215's and 225's when noone else has them i can check if you want...let me know
67pat is offline
post #6 of 28 (permalink) Old Jan 9th, 08, 01:29 PM
Lucky68's Avatar
I opted for 215/65-15 up front with 255/60-15's out back. It may be an option if you want to avoid the wait. The difference in tire diameter is: 215/60 = 25.2" vs 215/65 = 26"
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
Lucky68 is offline
post #7 of 28 (permalink) Old Jan 9th, 08, 02:05 PM
Kevin
SixtyAte's Avatar
Edit:
Mike, I run 225 -15 on a 8 in rim with disk brakes and they rub in a hard turn and bad bump.
Kev
SixtyAte is offline
post #8 of 28 (permalink) Old Jan 9th, 08, 02:09 PM
Nick
Rarerat's Avatar
I ran 225 60 15's on 7" ralleys on the front of my 68 with no problems.
I hope this helps
Rarerat is offline
post #9 of 28 (permalink) Old Jan 18th, 08, 03:00 PM
I also am waiting i was told i got month to wait this monday..
hjoe is offline
post #10 of 28 (permalink) Old Jan 19th, 08, 07:50 AM
I am about to try 225/70R15 on my 68. I am hoping these will work with no rubbing.
brickyard02camaro is offline
post #11 of 28 (permalink) Old Jan 19th, 08, 08:01 AM
"Tri-Tip"
Gary L's Avatar
215/65R15 look better. More in proportion.
Gary L is offline
post #12 of 28 (permalink) Old Jan 19th, 08, 08:13 AM
I already had the 225/70R15. I am taking them off one car so I can buy new wheels and tires for another. Not sure if they will work but I am hoping.
post #13 of 28 (permalink) Old Feb 5th, 08, 11:22 AM
Bill
I'm currently running the P225 60 15s and the drivers tire will rub the fender front fender well when the wheel is cranked all the way during a left turn. It didn't do this with stock drums/spindles but started when I converted to SSBC discs/spindles. I'm now also looking for a substitute size w/slightly less diameter. What about 50-15s up front? Anyone running them? I've also seen some 55-15s made by another co.
68RS-SS is offline
post #14 of 28 (permalink) Old Feb 5th, 08, 11:51 AM
Rex
maybe you should look to another brand?
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #15 of 28 (permalink) Old Feb 15th, 08, 02:24 PM
just an update...........I could not get the 215 65 15 to work on my 68
I had to go to a 205 65
