Wheels and tires finally on their way!! - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 8th, 08, 10:32 AM Thread Starter
bl
Send a message via MSN to bl1work
I found the exact wheels i wanted for my 69 about 2yrs before it was finally painted and needed wheels and when I went to order them this summer they were discontinued... I've been in a long search to find a replacement that I liked better and I had settled on centerline daggers, these being considerably more expensive and still not my first choice. I was planning on ordering them next week and yesterday I got an email from the company where the original wheels I wanted were at. Basically, the guy I had talked with was no longer there and they were doing followups and inventory. They had done inventory and found 2 sets left of the wheels i was after. So I ordered them on the spot with tires... This is my first set of wheels/tires for my 69 so as far as what would fit... I did extensive research on the groups here to come up with the widest tire/wheel i could run in the rear in a 17". Well there on their way now so I hope they fit with minimal headaches... heres' what i got... 17x 8 x 4.75 x 4.5BS fronts, 17 x 9 x 4.75 x 5.65BS rears... tires 235 45wr17 front, 275-40wr17 rear. http://www.groupawheels.com/Catalog....r&category=ALL Let me know you guys opinions... fit or anything.
thanks,
bl
bl1work is offline
post #2 of 13 (permalink) Old Jan 8th, 08, 11:04 AM
Kevin
Re: Wheels and tires finally on their way!!
Nice wheels and congrats. My only concern would the 4.75 bs for the rear, as I would bet dollars to donuts you'll get fender rub with 275's. 5" (a 1/4" difference) would have been a better choice, imho. In fact, I'd have rub on my 69' (with 9.5" wheel and 5.5" bs) with a 275 tire as is, but it's "centered" as best as can be for distance between inner/outer well. Your 9" wheel with 5" bs would be the equivalent of being centered....but 4.75 will put the wheel/tire out 1/4" more to the outside and I'm pretty sure you'll have issues. But...you might be able to roll the lip and solve it.
Learning & Relearning about the cars I grew up with.
69' - Built 350, 750 Holley, Elgin E920P Cam, 283 PP Heads, Long Comp Headers, MSD, TKO-600, 12 Bolt Posi 3.73, Hotchkis Rear, Eibach Front w/Hotchkis Sway, SPC UCAs, 3rd Gen PS, AR TTII's. Still working on it.
dbx1969 is offline
post #3 of 13 (permalink) Old Jan 8th, 08, 11:22 AM
Kevin - I think the 4.75 is the 4 3/4 bolt circle, and the number with BS after it is the backspace. So, at 5.65 BS in the back, dl might be okay based on your car.
I'd be a little concerned about the front backspace. I have 15 x 7 with a 215 60 on wheels with 4.75 inch backspace, with a lowered front end, and there's not a lot of room between the outside of the tire and the fender lip. Adding another 10 mm width 0.25 inch toward the fender lip would be close.
Eric
Eric Kammerer is offline
post #4 of 13 (permalink) Old Jan 8th, 08, 11:43 AM
Kevin
Damn it Eric! I will take a remedial reading course this afternoon.
Um...Bl...never mind .
dbx1969 is offline
post #5 of 13 (permalink) Old Jan 8th, 08, 12:42 PM Thread Starter
bl
I was really concerned about the rears, you think the fronts will be close ehh... my car is not lowered... disc brakes. That will be about right, if so I might have two front tires for sale.
bl1work is offline
post #6 of 13 (permalink) Old Jan 8th, 08, 01:22 PM
Kevin
I leave it to Eric to reply to the fronts, but....I'd still caution that you may have issues with the rear, even with the BS you have if you're using 275's. Every car is different, and 275 seems to be a 50/50 kinda deal as far as fitment goes on a 69'. However, if it does rub the inner well or exhaust pipe...you can always remedy it pretty easily.
dbx1969 is offline
post #7 of 13 (permalink) Old Jan 8th, 08, 05:08 PM Thread Starter
bl
If it rubs the inside i can easily make me a spacer for the hub... if it rubs the outer fender lip... then its different tire or lip roll... uggg....
bl1work is offline
post #8 of 13 (permalink) Old Jan 8th, 08, 08:04 PM
bl -
There are some pics of mine with various size tires and backspace in this thread: https://www.camaros.net/forums/showth...ighlight=tires
As I said, mine is pretty low in the front. The fender lip clearance was better once I got the correct amount of camber, and nothing rubs inside or out. You'll probably be fine.
P.S. Love the Daggers! You don't seem to see them that much, which I think is good.
Eric
post #9 of 13 (permalink) Old Jan 9th, 08, 07:14 AM Thread Starter
bl
Well, i've gotten a little nervous now and pulled a rear wheel off last night and started measuring... its gonna be tight, I don't know that my fender lip will be a problem though because the car is not lowered and the lip is 2-3 inches above the tire. I had installed a rear sway bar on the car, which has effectively stopped all flexing in the rear, actually it is too stiff back there now. Stiff too the point that when i turn onto my driveway, one of my rear tires will come off the ground! But i guess that will insure that i don't rub a tire on the fender. lol
bl
bl1work is offline
post #10 of 13 (permalink) Old Jan 9th, 08, 11:50 AM
Dr. Feelgood
4.5" b/s on a 17x8" front wheel is tight...but your saving grace is those 235/45 tires.You should be good there w/no worries,especially @ stock height.
Rears should be OK too with that 275/40 tire.If anything,you'll be a little close to the inner fender (nothing a BFH will cure) and if the exhaust tubes rub on the rears,just have them re-routed to dump before the axle...problem solved.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #11 of 13 (permalink) Old Jan 9th, 08, 12:43 PM Thread Starter
bl
BFH took me a min... lol I won't have an exhaust tube problem, I looked at that last night and i'm not anywhere close to them. The closest thing I see is the shock mt on the bottom of my leaf spring plate, but I'm thinking it will end up inside my rim. The wait on the wheels coming in is killing me...
bl1work is offline
post #12 of 13 (permalink) Old Jan 9th, 08, 03:12 PM
Dr. Feelgood
The closest thing I see is the shock mt on the bottom of my leaf spring plate, but I'm thinking it will end up inside my rim...
Yes it will.
lol on the BFH comment...
post #13 of 13 (permalink) Old Jan 9th, 08, 05:05 PM
Boo
John/Eric or anyone else that would like to chime in, I would like to get your opinion my boots. I started a thread a few days ago because I'm getting a little pizzed with the rub I'm getting.
Thanks.
https://www.camaros.net/forums/showthread.php?t=124285
My Ride:
1968 Camaro SS Clone
booman55 is offline
