67 Front tire size - Team Camaro Tech
post #1 of 21 (permalink) Old Jan 9th, 08, 05:11 PM Thread Starter
67 Front tire size
Would it make much difference going from a 235-60-15 BFG to a 225-60-15 ? I get tire rub on the fender bolts and frame . It takes a large bump to make it scrub. Trying to eliminate tire scrub.
67sprtcp is offline
post #2 of 21 (permalink) Old Jan 9th, 08, 05:36 PM
Re: 67 Front tire size
I got tire rub on 225 too.
fotoboy is offline
post #3 of 21 (permalink) Old Jan 9th, 08, 06:49 PM
If it's a 1967 or 1968 you may have to go down to P215/65/R15. I would recommend P 215/60/R15 (see below)....As far as P215/65/R15; this size was used on many GM cars so it should still be available. The Z28's & also the 5.0L IROC-Z's used it from 1982-1987 & from 1985-1990. During the 1980's it was also used on Olds Cutlass Supreme in both RWD & FWD configurations. The Buick Regal GN also used it, The Monte Carlso SS used it too....
I wasn't born yet when the first 1967 Camaro rolled off the assembly line. But if I recall my history correctly the 1967 Z28 was equipped with E70x15 which equates to P215/60R15....If you have a 1967 that is what I would go with.
Here is a helpful link for tire size conversion http://www.turbinecar.com/tires.htm
Here is another cool link for tires
http://www.1010tires.com/TireSizeCal...?action=submit
In my experience with these cars (mostly from 1989 -1998) you could get more tire on the front of 1969 then on a 1967 or 1968 but more tire on the back of a 1967 or 1968 than a 1969.
Good Luck!!
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #4 of 21 (permalink) Old Jan 9th, 08, 07:19 PM Thread Starter
Thanks for the info.
67sprtcp is offline
post #5 of 21 (permalink) Old Jan 9th, 08, 07:59 PM
1st 67 SS/RS's Avatar
I have a 67 vert with a Hotchkis TVS package (2" drop springs in front) with 15x7 rallys and 245/60's all around. I had to change out my old body mounts to stop the rubbing. Do you have stock springs, are they old? How are the body mounts? What type of rims and what is the back spacing? You need to give some more info to help us answer your question.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #6 of 21 (permalink) Old Jan 10th, 08, 12:16 PM Thread Starter
Stock springs, probably pretty old. Body bushings are fair, but could be replaced. 15 x 7 rallys front and rear , 4 1/4 backspacing. Shocks look to be fairly new but are carquest brand. What other items should I check?
67sprtcp is offline
post #7 of 21 (permalink) Old Jan 10th, 08, 12:35 PM
Pat
I run 225's on the front on 15x7 ralleys with no rub,BUT I have the TVS kit as well and as David Pozzi's site says I run almost +3 on the caster for my alignment #'s which has changed the whole handling of the car
67pat is offline
post #8 of 21 (permalink) Old Jan 11th, 08, 06:19 AM
You could replace the front springs with a stiffer spring like Hocthkis (2" drop 600lb/in rate) ~$160 or Global West (1" drop) ~$150 or a stock style spring ~$80ish. The body mounts start at around $40 for rubber and go up to $100 for polygraphite or solid mounts. But you only gain maybe a 1/2" or so depending on how bad the old mounts are flattened. New shocks could help some but you might have to go stiffer. My Bilsteins for the Hotchkis kit run from $75 to $100ea, not cheap. There are the Koni shocks too. You would probably get more help from new or stiffer springs than the mounts or shocks depending on how old the springs and shocks are. Mounts are not that bad to replace, just do one side at a time and don't jack the to far up or you could push the body panels out of alignment, learned that the hard way.
post #9 of 21 (permalink) Old Jan 11th, 08, 05:28 PM Thread Starter
I will do more inspecting of the front suspension and decide what all to replace. Iwill check all the body bushings too. Thanks for the info.
67sprtcp is offline
post #10 of 21 (permalink) Old Jan 12th, 08, 10:09 PM
I forgot, one other option is Global West makes a shim for the front springs. It's a C shaped ring that is groved so your spring sits on top of it. They have a few different sizes. I bought some ($30/pair) thinking I would use them but did not need them after replacing the body mounts. Mine are the 3/8" shim which should give roughly 5/8" increase in height from what I am told.
post #11 of 21 (permalink) Old Jan 16th, 08, 01:24 PM
Charlie
I had BFG's 235's on the front and got the same rub you have. This was when i just turn the wheel a bit and hit a small bump. I put 225's on the front and now no rub. I still get a little rub if i cut the wheel hard in my driveway or trying to cut into a parking spot that is tight. but no more rubbing when on a slight turn and hit a bump.
Ironman24 is offline
post #12 of 21 (permalink) Old Jan 17th, 08, 07:01 PM Thread Starter
Thanks. I may try the 225s.
67sprtcp is offline
post #13 of 21 (permalink) Old Jan 18th, 08, 05:41 PM
Mine came w/ Firestone Wide-Oval Redline D-70/14's that are about 200-70/14's.
pdq67
post #14 of 21 (permalink) Old Aug 5th, 13, 11:44 AM
Gino
Quick question on wheel/rims. I am thinking about getting a 17x7 rallye for my 67 camaro with 4 1/2. Will it rub?
ginocamaro is offline
post #15 of 21 (permalink) Old Mar 6th, 14, 11:12 AM
Ronnie
What do you think of a 26X8.00R18LT to wide?
Marine67 is offline
