Clearance issue - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 20th, 08, 06:05 AM Thread Starter
Clearance issue
Which of the following will fit the front of a 69 better, 15 x7 w/ 3.75 bs or 15 x 6 w/3.25 bs. Also a tire recommendation would be great. Dont want any tire rubbing issues.Thanks
paperman is offline
post #2 of 7 (permalink) Old Jan 20th, 08, 06:12 AM
Re: Clearance issue
The 6" rim with 3 3/4" BS will exten out toward the fender lip 1" less than a 7" rim with the same backspace. (Since the backspace is the same, all the added rim width is on the outside.)
I won't comment on actual fit on a 69 tho. My rims, with 3 7/8" BS on a 7", clear fine on a very low 68 with 225 tires.
post #3 of 7 (permalink) Old Jan 20th, 08, 06:15 AM Thread Starter
Re: Clearance issue
It isnt the same bs, one is 3.75 and the other is 3.25
paperman is offline
post #4 of 7 (permalink) Old Jan 20th, 08, 06:41 AM
Kevin
SixtyAte's Avatar
Re: Clearance issue
Brian...
The less the backspace the more it will stick out. Then add in the width of the rim and it will stick out that much more.
A 15x8 rim with 4.5 backspace will stick out the same as a 15x7 rim with 3.5 backspace. And if you have aftermarket disk brakes it will stick out about a 1/2 in more.
Kev
SixtyAte is offline
post #5 of 7 (permalink) Old Jan 20th, 08, 07:10 AM
Re: Clearance issue
Oh... Gues I can't read properly this early then. Like Kev said, same same.
post #6 of 7 (permalink) Old Jan 20th, 08, 04:22 PM
Re: Clearance issue
they aren't going to fit the same
7" - 3.75" = 3.25" sticking out from the hub
6" - 3.25" = 2.75" sticking out from the hub
but like JimM i don't want to recommend which will work for you
but I will say that the 6" wide rims are much more likely to fit without a problem
in truth, I would probably go with the 7" wide rims (they only stick out an 1/8" further than JimM's)
400bird is offline
post #7 of 7 (permalink) Old Jan 21st, 08, 07:58 AM
Re: Clearance issue
I had Fenton Slotted Mags, 14" x 7" w/ 3.5" b/s and E-60's on my front for years. Still mounted up on my shelf.
IT AIN'T WORTH THE HASSLE to me, use stock at 15" x 6" w/ 3.75" b/s and not have any fitment issues!
That extra inch is the killer unless the b/s is 4.75!!
pdq67
