What size ? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 21st, 08, 06:59 PM Thread Starter
What size ?
Want to put 16" Torque Thrust wheels on my 68. 16x8 on rear 16x7 on frt. ? What size tires ? Want to put disc brakes & drop spindles on it at the same time. Wondering about the clearance issue.
herb68 is offline
post #2 of 4 (permalink) Old Jan 21st, 08, 09:54 PM
Re: What size ?
I've got 225/50R16 in front
and 245/50R16 in the rear
I could go 10mm wider both front and rear, but the tires I got did not come in those sizes
i recommend you measure the backspacing yourself, and do a few searches to see what has worked for others
and I would recommend stepping up to 17" because there are a lot more tires available, and you can get a 275/40R17, no one makes a 275 for 16's
and search on drop spindles, they will cause you a lot of problems
everyone recommends drop springs
400bird is offline
post #3 of 4 (permalink) Old Jan 23rd, 08, 06:05 PM
Kevin
Re: What size ?
I have 16" wheels, with 235/55 on the front on 7 inch rims, and 295/50 on the back on 9.5 inch rims. Some things to also know:
On the front I have the DSE coilover system using their control arms. On the back, I have DSE minitubs and their Quadralink 4-link setup.
If I had to do it over again, I don't know if I would use 16" as my wheel size, because the tire choices are very VERY limited. I made this choice because I thought that I could fit a larger disk brake system on 16 rims when in fact you will almost always have to use a disk brake system for 15-inch wheels. The only way to get any larger disks is to go to 17 inch, which also gives you almost unlimited choices in tires. But for me, I just don't (personally) like the look of 17 inches on my '68, but I like them on '69s.
I also find wide tires for 15 inch rims a bit hard to find too. Except for M/T, I can't think who else makes a wide tire for 15" wheels. Another mistake I made was ASSuming that a tire size from BFG was available based on BFG's web site and chart. I ordered my wheels and when I went to order the tires for the rear, I found that they had not been made for some time and there was a 'waiting list' to get them and they had no idea if they were going to make them anymore (the 295 series). After doing a nationwide search, I got lucky and found only one company, Cooper, that makes a wide 16 inch tire.
So, the lesson is if you have an odd wheel size, don't order the rims until you know 100% for sure that the tire size that you want is available. Don't trust the dealers or manufacturer's web sites.
Hope this helps.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
post #4 of 4 (permalink) Old Jan 23rd, 08, 11:18 PM
Re: What size ?
well, i never checked for a 295/50R16
thats good to know, but Im glad someone else can back me up that with 16" rims you are limited in tire choices
400bird is offline
