16X8 wheel with 5" backspace, will that work on the front? - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 22nd, 08, 10:25 PM Thread Starter
Is 5" backspace to much on a 16X8 wheel on the front of my 67 or will it fit OK? Thanks for the help!
Steve88 is offline
post #2 of 12 (permalink) Old Jul 23rd, 08, 02:55 PM
Kevin
SixtyAte's Avatar
Re: 16X8 wheel with 5" backspace, will that work on the front?
The 5" backspace is a bit too much. You should put a bare 4 or 4.5 rim on there and add the difference extending into the wheel housing. You should be rubbing on the inside. I run 4.5 with disk brakes and it rubs on hard turns with 225-60-R15 tires.
Kev
SixtyAte is offline
post #3 of 12 (permalink) Old Jul 23rd, 08, 08:12 PM
class67's Avatar
I have an 18x8 on the front of my 67 with 5" BS and it is perfect...no rubbing!
67 Camaro RS
class67 is offline
post #4 of 12 (permalink) Old Aug 5th, 08, 02:07 PM
Rich
my 69 bird had 16x8 w 255/50/16 with i believe 4.5" B/S with no issues same tires and wheels also fit my 87 t/a
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #5 of 12 (permalink) Old Aug 6th, 08, 05:25 AM
I have 16 x 8 with 4.5 back space. I have installed after market disc brakes and I was told that they move the wheel out and extra 3/8" and my tires are right on the edge of the wheel lip. I had a rub on the inside bolts on turns and the upper bolts on bumps.
I cured that by going to a cap screw on the fender bolts and a 50 series tire.
No rubs now.
I think the five might be just a little much. It would also depend on your suspension and brake set up.
Before I put the 6308 coils in, it had big block springs and drum brakes and I still got a rub on the inside lower fender bolt on tight turns with 235/60/15s.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #6 of 12 (permalink) Old Aug 12th, 08, 02:52 PM
6D9
Ron
How low is your car????
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #7 of 12 (permalink) Old Aug 12th, 08, 04:19 PM
Kevin
I have 16x7 with 4" of BS and they rub. The part that is rubbing is the outer part of the inner fender, right behind the actual fender lip. According to Detroit Speed, with a 7" wheel you should run 4-1/4" to 4-3/8" of BS. I plan on trying a set with 4.5" of spacing since my Centerlines have to be in 1/2" increments.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
post #8 of 12 (permalink) Old Aug 12th, 08, 06:33 PM
I run 17x7, 4" bs, 225-50-16 tires. Car is very low.
No rubbing ever. Just lucky I guess?
8" rim with 4 1/2" bs should be ideal, but these cars are all different.
post #9 of 12 (permalink) Old Aug 12th, 08, 06:50 PM
Kevin
I assume you mean 225-50-17 ? Mine are 235-55-16 with the 4" BS. Rubba rubba in the wheel tubba. I just came up with that; should trademark it maybe.
I also have the DSE front coilovers and already took it apart once (no fun) to raise it up (no help). That was why I called DSE and they gave me what they would put on it it they were building it.
-Kevin
post #10 of 12 (permalink) Old Aug 12th, 08, 06:52 PM
Kevin
Another thing I forgot to point out is that if you put too MUCH backspace on the front, you can always put a shim ring on and play with it, but if you have too little (like me) you are S.O.L.
-Kevin
post #11 of 12 (permalink) Old Aug 12th, 08, 07:18 PM
Naaa, the other end was a typo, rims are 16x7, not 17.
My front tires are short, 23.5". That makes a difference, the taller the wheel is, the more space it takes up when you turn and the more likely it is to get into either the front or rear inner fender bolts, or the framerail.
Another thing many don't see is the effect the suspension's camber, and camber change on compression, makes with tire clearance.
The standard geometry cambers the top of the tire OUT when the fender compresses. With the guldstrand mod, my tire cambers in. With the car straight and at ride ht, you can't get your hand between the tire and the fender lip, but it never rubs.
Your 235-55's are pushing the envelope a bit on a 67-68 in front. The 225-50's are a lil narrower and more than a little shorter.
post #12 of 12 (permalink) Old Aug 12th, 08, 08:07 PM
Kevin
You got me thinking again that maybe instead of changing my wheel out (expensive and I'll never find someone to buy my new fronts now), maybe I should just try a different tire size. Duh. Keeping the same brand of tire (Cooper Cobra), they have a 215/55. Thats the only other option, unless I use a different brand on the front. I guess I could, since I'm a blackwall out now front and rear. But would that look goofy since the thread pattern is different ?
I like the look of the 235/55, and I have not professionally aligned the front yet, and I was going to get that done before I started changing things out.
-Kevin
