biggest wheels - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 30th, 08, 09:17 AM Thread Starter
biggest wheels
Hi,
I was just wondering, what are the biggest wheels that you can use on a stock 1969 camaro, no suspension changes
thanks
drumbumz28 is offline
post #2 of 4 (permalink) Old Jul 30th, 08, 05:25 PM
Re: biggest wheels
Width or diameter?
More info would be helpfull. 17" wheels or bigger sometimes look out of place if the car sits high. As a starting point an 8" wheel will work on the front and a 9.5" will work in the rear in 17" or larger diameter.
Jack
JV69z/28rs is offline
post #3 of 4 (permalink) Old Jul 30th, 08, 06:46 PM
Dr. Feelgood
Re: biggest wheels
Jack is right,if the stance is wrong,a bigger wheel will have you too high up in the air.
If we're talking about diameter,common no-hassle sizes that will fit right out of the box are as follows:
Fronts:
17x8 (4.5" b/s) better would be 4.75" or even 4.875"
245/45-17's
Rears:
17x9.5 (5.5" b/s) w/275/40-17's
Now each car is different so you really need to measure.I am currently running a 18x10 rear (5.625" b/s) w/275/40-18's and I could have either run a slightly bigger tire or gone with just 5.5" b/s...I have that much more room to play with.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #4 of 4 (permalink) Old Jul 30th, 08, 06:56 PM
Patrick
Re: biggest wheels
I have 18's on mine and I lowered it.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
