17 x 9, 6 " backspacing too much on a 68? - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 18th, 08, 07:56 AM Thread Starter
Ryan
Send a message via AIM to rp0029
I am looking at these AR6987963 (ARE Razors) for my rears.
They are 17x9, 6" BS, 5 x 4 3/4 wheels.
I want to run Falken FK-452s, part no 2819-5714 on them.
They are Size: 275/40ZR17 Rating: 98Y Height: 25.7" Width: 10.9"
Do you all think they will rub at all?
Black 1968 Coupe.
Build thread
Modern, fuel injected LS engine DAILY DRIVER!
rp0029 is offline
post #2 of 8 (permalink) Old Aug 18th, 08, 12:47 PM
Re: 17 x 9, 6 " backspacing too much on a 68?
You will probably need a half inch spacer to make those wheels work.
dhutton is offline
post #3 of 8 (permalink) Old Aug 18th, 08, 02:24 PM
Len Barron
Originally Posted by dhutton View Post
you Will Probably Need A Half Inch Spacer To Make Those Wheels Work.
X2
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
LCAC_Man is offline
post #4 of 8 (permalink) Old Aug 18th, 08, 04:27 PM Thread Starter
Ryan
Will the spacer affect drivability at all?
Black 1968 Coupe.
Build thread
rp0029 is offline
post #5 of 8 (permalink) Old Aug 18th, 08, 05:41 PM
Half inch spacers are a little tricky because it is too thick for a simple spacer and too thin for a bolt on adaptor.
You can read more here:
http://www.skulte.com/info_pages.php/pages_id/3
Cragar does make them though, Summit sells them.
dhutton is offline
post #6 of 8 (permalink) Old Aug 19th, 08, 03:19 PM
Smile Re: 17 x 9, 6 " backspacing too much on a 68?
7/16" spacers are on my car now, but I had Moser's redrill and tap mine to 1/2" stud size.
pdq67
post #7 of 8 (permalink) Old Aug 19th, 08, 06:09 PM Thread Starter
Ryan
I've decided to go with the the 5.5" bs TT IIs, like everyone else. 17x9.5 w/ 5.5 bs. ARE-405-7956155. I just measured my wheel wells and I have at least 6" from the face of my drums in the rear.
Black 1968 Coupe.
Build thread
rp0029 is offline
post #8 of 8 (permalink) Old Aug 20th, 08, 04:32 PM
Remember, IT'S THE SECTION WIDTH of the tire that stick's out past the rim faces on both sides that end up rubbing so PLEASE really do your homework!!!!
It's ALL here if you just do a search and if you are really into this, then please consider going over to Larry C's great PT site, "Pro-Touring" and ask the guys over there!
The PT guys are really into wide and low for that look and performance that come's w/ it AND I ain't talking about posing either here at all!!!! A bunch of the PT guys drive their cars HARD so they can't RUB!!
And if you do, please say hello to Larry from ol' pdq67 for me!
pdq676
