1968 Tire and rim problem - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 10th, 08, 12:13 PM Thread Starter
Hey guys
I have recently replaced my stock 14" rally wheels 6" width and tires 235/70s with 15" 7 inch cragar ss and 15" 235/60s. I now have wheel rub on front on a hard right turn and bottoming out in minor dips hitting fender bolts. What to do??
canuckgambler is offline
post #2 of 4 (permalink) Old Sep 10th, 08, 01:43 PM
Ryan
Re: 1968 Tire and rim problem
It sounds as if your backspacing isn't correct. Your wheel tire combo should end up almost exactly the same width and a little under an inch shorter in height. Do you know what the difference is between the backspacing of your new and old wheels?
Rhino is offline
post #3 of 4 (permalink) Old Sep 10th, 08, 02:10 PM
Back spacing should be at least 4" preferably 4 1/2"
1969 Camaro, 548ci, 10.6:1, solid roller, Ford AOD, 4000 Stall, 12 bolt with 4.11's
New best, 10.59 at 125.48, 1.39 60ft
Cali Z28 is offline
post #4 of 4 (permalink) Old Sep 10th, 08, 05:12 PM
On a 7" rim, b/s should be 4"
235 is a lil big, and may rub some.
Where is it rubbing on hard turns? On the framerail?
