69 with mono leafs 275/50/15? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 10th, 08, 07:48 PM Thread Starter
Darren
I ordered a set of tires that were 275/60/15 and didn't even try to mount them. It was obvious they wouldn't fit. My old leafs probably let the car sag a little, but how much tire can I fit under there? I want some MT ET Streets, but just don't know what size to run. Anyone have a comparable situation?
Darren
67 Camaro 350
69 Camaro 406 10-1 comp, afr 195s, performer rpm intake, 750 DP, comp 286h
67CamaroD is offline
post #2 of 4 (permalink) Old Oct 10th, 08, 11:03 PM
6D9
Ron
Re: 69 with mono leafs 275/50/15?
Im running 275/50/15 MT DR's. They are on 15x8's with 4.5" bs wheels.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #3 of 4 (permalink) Old Oct 11th, 08, 12:24 AM
Len Barron
A 275 will fit but you will need to;
1) correct your suspension(JCW springs are popular for this) to elevate the quarter lip well above the tire, or if your mono's aren't too bad;
2) use a wheel with the correct backspacing to allow the tire to center perfectly in the wheel well (even with this you'd probably need to trim some from the quarter well lip).
Doing both of the above is actually the best fix.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
LCAC_Man is offline
post #4 of 4 (permalink) Old Oct 11th, 08, 08:41 AM
Dan
I have a set of 275/60-15 on my car and I do have the mono spring(not new springs) the trick to getting them to work is 4.5 back spacing on your wheels.I also used a 7" rally rim(see signiture) fit great.No problem.I also use the 235/60-15 on the front,with the same rim size.15x7 rally with 4.5 back spacing. Hope this helps....
________________________________
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
