Rally wheel code - Team Camaro Tech
post #1 of 11 (permalink) Old Mar 4th, 09, 04:35 PM Thread Starter
Tim
NANDOG's Avatar
Rally wheel code
Sorry, probably been posted before but I don't have the time to search and read.
A set of wheels with the code: K-1-3 4 (valve stem) 26 FW
I know they're 15 x 7s but I get confused with the left hand code.
TIA!
NANDOG is offline
post #2 of 11 (permalink) Old Mar 4th, 09, 06:07 PM
bigsteve
Re: Rally wheel code
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camero & Chevelle with dics brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camero & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camero with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camero/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camero, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camero &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camero Z28
DC(BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Rivited instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
FW 15X7 B-4 1/4 71-up most any GM
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
Heres a few extra notes
All the rally wheels made in 1967 have big marking letters, no date code, a little bit different shaped center and slightly bigger holes in the center
The 15x7 beauty ring with go on all the 15x6 wheels
All the hubcaps interchange with each other
I'll post how to read the date codes later
Hope somebody can use this
bigsteve is offline
post #3 of 11 (permalink) Old Mar 4th, 09, 06:32 PM
hello nandog,
the date code breaks down like this;
K = kelsey-hayes designation
1 = romulus,mi plant
3 = 1973
4 = the month of the year
26 = the day of the month
FW = the wheel code
Mark B is offline
post #4 of 11 (permalink) Old Mar 4th, 09, 06:52 PM
Russ
rafbody's Avatar
That is a great list. I don't know about the other wheels but the "DA" wheels were also used on 67 non ss Camaros with disc brakes.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #5 of 11 (permalink) Old Mar 5th, 09, 02:09 PM Thread Starter
Tim
NANDOG's Avatar
Thanks so much for the info, gentlemen!
NANDOG is offline
post #6 of 11 (permalink) Old Mar 5th, 09, 03:00 PM
hey guys dont mean to be a topic breaker but i wonder if you know if trim rings on 15x7 rally wheels, fit 15x7 ss wheels? or are they somehow altered to just fit the rallys? thnks..john
Cam6t9 is offline
post #7 of 11 (permalink) Old Mar 5th, 09, 06:01 PM
Jonesy's Avatar
FW code wheels are 15x7 Monte Carlo/Chevelle Ralley wheels. In this case that wheel is off a 1973 Chevelle or Monte Carlo. It was made April 26, 1973.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #8 of 11 (permalink) Old Oct 8th, 12, 04:48 PM
Wayne
Big Steve,
Your post is very informative. I believe however you missed 1967 Camaro RS without disc brakes. What are the correct wheel size and codes for this.
Thanks.
awyoung is offline
post #9 of 11 (permalink) Old Oct 9th, 12, 01:52 AM
Garth
Hi Wayne welcome aboard ! You should start a new thread for a better response....
14x5 was standard, 14x6 optional. See the chart with codes in the following link....
http://camaros.org/suspen.shtml#Wheels
Garfields Maro is offline
post #10 of 11 (permalink) Old Oct 9th, 12, 07:49 AM
Red face Re: Rally wheel code
What is a Camero ? Is that some type of a Camera ?
TJS69 is offline
post #11 of 11 (permalink) Old Mar 6th, 19, 07:57 PM
Probationer
Can you explain why my Rally wheels are stamped 25 FW k 1 9 or 8 and 31 FW GK 1-3.. thx... not much marking on them.. tge FW at Valve stem is large
Joe 69Nova is offline
