69 Wheel Backspacing - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 30th, 09, 03:09 PM Thread Starter
Dante'
Anybody running 18x7s with 4.5 backspacing front and 18x8 with 4.5 backspacing in the rear? I found a good deal and this is the only size.
69 Camaro SS
windycity1 is offline
post #2 of 6 (permalink) Old Mar 30th, 09, 04:29 PM
Re: 69 Wheel Backspacing
Those sizes will work but they won't fill the wheel wells. To compare: 18x8 with 4.75 backspace in the front and 18x9.5 in the rear with 5.5 backspace. As you can see you are within the reccommended sizes.
Jack
JV69z/28rs is offline
post #3 of 6 (permalink) Old Mar 31st, 09, 03:23 PM Thread Starter
Dante'
Why wouldn't these sizes fill the wheel wells with the right size tire?
69 Camaro SS
post #4 of 6 (permalink) Old Mar 31st, 09, 06:32 PM
Because you can fit wider and the same size tire on a wider wheel IS wider - .2" for every 1/2" of wheel I believe. Don't take it as a negative that's not how I meant it. The only point was to tell you that wider wheels will fit.
Jack
post #5 of 6 (permalink) Old Apr 1st, 09, 03:54 PM Thread Starter
Dante'
Thanks Jack, I didn't take it as negative, I just did not understand what you were saying. I value all forum information and advice.
69 Camaro SS
post #6 of 6 (permalink) Old Apr 1st, 09, 04:10 PM
Dr. Feelgood
Jack is right on that setup above,that should work perfectly.
If the particular wheel you're looking at doesn't do 1/4" increments,a 4.5" b/s on an 8" wide front wheel will work too but 4.75" is better and 4.875" is even better.
As you can see,you're pushing the wheel away from the outer fenders which is what you want.
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
