rally rims 15 x 7 JJ code? help identify - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 15th, 09, 06:49 PM Thread Starter
frank
I have an opportunity to buy these rims and was told that they are JJ code. I went into the search as while there ar many threads about codes, I didnt see one that says JJ. Did the guy read it wrong. He took the letter off the inside of the rim, above the stem. any help is appreciated
viper is offline
post #2 of 3 (permalink) Old Apr 15th, 09, 07:22 PM
Re: rally rims 15 x 7 JJ code? help identify
The JJ is the profile of the rim and comes off the inside diameter of the wheel. The application code and date code is on the right side of the valve stem opening on the outside face of the wheel. The year and assembly plant code is on the left side of the valve stem opening.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 3 (permalink) Old Apr 16th, 09, 02:14 PM Thread Starter
frank
thanks Mark, any way of knowing if these are for a camaro
viper is offline
