Bf goodrich drag radials - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 15th, 09, 07:44 PM Thread Starter
Chris
Just bought a set of 275-60-15s. What should I expect?
hirpms is offline
post #2 of 7 (permalink) Old Apr 15th, 09, 07:51 PM
Paul
Re: Bf goodrich drag radials
I dunno but I ran low 12's with 245/60/15 BFG drag radials...
Best of 1.55 - [email protected]
paulm is offline
post #3 of 7 (permalink) Old Apr 15th, 09, 08:30 PM
Good tires the BFG Drag radials! Your ET times should drop and they will stick alot better at the track.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #4 of 7 (permalink) Old Apr 15th, 09, 08:53 PM
Jason
69 Bowtie's Avatar
I found them to be a great street/strip tire.
69 X-44/ 427BB/ M22/ 12 bolt
Muscle cars, more expensive than crack!
69 Bowtie is offline
post #5 of 7 (permalink) Old Apr 16th, 09, 08:17 AM
Sean
I went 11.70 on a pair and they always hooked for me at the track. They drive decent and wear decent as well. On my Mustang I used to use as a daily driver I ran a pair, they lasted about a year per set.
However the M/T ET drag radials are better still, they are stickier and the ride is just as good on the street. The other thing I have found is my BFG's liked a big burnout and the M/T's don't need to be much more than heated up, so using them at the track the M/T' seem to have lasted longer.
Either tire is a great street strip compromise and are perfectly capable of low 11's high 10's without major tricks, and even faster with some dialing in the suspension. There are cars going well into the 7's on 275-60/15 ET drag radials .
Sean
Franklin D. Roosevelt
68rs406 is online now
post #6 of 7 (permalink) Old Apr 16th, 09, 09:18 AM Thread Starter
Chris
Sounds like I made a good choice! They look good too!
hirpms is offline
post #7 of 7 (permalink) Old Apr 16th, 09, 05:11 PM Thread Starter
Chris
I do need to get a little wider rim. I have a 7inch.
hirpms is offline
