my tires to big????? - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 22nd, 09, 01:02 PM Thread Starter
Exclamation my tires to big?????
i have talk to 6 differnet people about my front tires everyone give me a differnet answer! what up with that?
i have a 1969 camaro 350 when i turn or hit bump the tires rub! the tire are p215/70/r15 the tires oonly rub when i turn
camaro9 is offline
post #2 of 9 (permalink) Old Apr 22nd, 09, 01:08 PM
Todd
Re: my tires to big?????
If they rub then your tires are to large, your ride height is to low, or you wheel offset is wrong. Stock tire diameter is 26" they are to tall at 27".
Vegas69 is offline
post #3 of 9 (permalink) Old Apr 22nd, 09, 01:10 PM
67 Convertible's Avatar
I would say the 70's are too high.
I have 215-60-15's on the front of my '67 with zero issues.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #4 of 9 (permalink) Old Apr 22nd, 09, 01:10 PM
Jerome
What's the back space of your wheels???,rub's inside or outside edge??? 215 70 maybe to tall ,I think 27 in dia ...??
1972 Nova SS , 350, Auto, AC, Survivor
68Lemans blue is offline
post #5 of 9 (permalink) Old Apr 22nd, 09, 01:25 PM
DjD
DjD's Avatar
A '69 Z/28 got E70 15's or in todays sizes 205/70x15 which is 26.3" tall and 8.2" section width. Other '69's might have had F70 14's which are like a 215/70x14 which is 25.9" tall with a 8.7" section width.
Yours are 26.9 tall, 8.7" section which is a bit tall and likely why they rub. Where do they rub? If at the outer fender lip it could be alignment, at the frame rails they are just too tall.
...Dennis
DjD is offline
post #6 of 9 (permalink) Old Apr 22nd, 09, 03:32 PM Thread Starter
Thumbs down Re: my tires to big?????
hi again
thanks for answer my question when you guys say to tall do yo mean from the ground to the top of the tire? i was tld went i bought these tire they will fit that what i get when you order tires from guy that know nothing about tires
camaro9 is offline
post #7 of 9 (permalink) Old Apr 22nd, 09, 04:04 PM
Todd
Diameter
Vegas69 is offline
post #8 of 9 (permalink) Old Apr 22nd, 09, 04:59 PM
I am not a tech guy but I thought the biggest stock size for the front is 215/65/15
1969 original SS in family since 1971.350/330 crate w/ comp 270 roller cam,2004R,355 12 Bolt posi,P/S P/FTD Brakes P/W P/TOP Orig A/C car but removed.
Car nut is offline
post #9 of 9 (permalink) Old Apr 22nd, 09, 05:20 PM
DjD
DjD's Avatar
Metric tire sizes are not stock for these old cars. The 215/65/15 is 25.8" tall with an 8.9" section width. The E70 15 ('69 Z tire size) was 26.4" so the 205/70/15 is closer in height. F70 14 could be found on non-Z cars in '69 and it's 26.2" tall and the 215/70/14 is 25.9" so your 215/65 is closer but it's a 15" wheel and for the context of this thread only the Z got a 15" wheel so to split hairs the 215/70/14 would be closer to stock based on wheel size.
...Dennis
DjD is offline
