what size lug nuts?? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 24th, 09, 05:30 PM Thread Starter
shane
I pulled the trigger this morning on a set of TTII's for my 69'. (real original right?)
What are the best size lug nuts to use??
Im sure someone here knows
Also, the bolt pattern is 5 4.75 right?.... cause that's what I ordered.
THANKS
carbon69 is offline
post #2 of 7 (permalink) Old Apr 25th, 09, 07:31 AM
Re: what size lug nuts??
Right, 5 x 4.75".
I'd use what they tell you to use w/ their wheels!
I say this b/c if I remember right, they may need flat stepped w/ washer lugnuts and the centering step part needs to be the right length. If it's too long, it will bottom out and the wheel will still be mounted, but tight lugnut-wise, loose to the hub/axle flange!
I do know my Bullitts use stock Ford v-coned type lugnuts. Much different than my old Fenton slotted mags that use what I mentioned earlier. And make sure the washers don't break!
pdq67
post #3 of 7 (permalink) Old Apr 25th, 09, 08:04 PM
joseph l clance
joe clance's Avatar
the TTII's come with the proper flared lug nuts. they are 7/16 X 20 thread. Demand they provide the AR nuts that come supplied with each wheel!
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #4 of 7 (permalink) Old Apr 26th, 09, 04:50 PM
X2
They were so generous on mine, they sent me 80 lug nuts.
BPOS is offline
post #5 of 7 (permalink) Old Apr 26th, 09, 07:02 PM Thread Starter
shane
oh nice. wow 80 seems a little excessive
carbon69 is offline
post #6 of 7 (permalink) Old Apr 27th, 09, 11:15 AM
Den
DenRS's Avatar
Wow, when I ordered my Hopster rims, I didn't get any lugs. They take the acorn style lugs which I had from my previous rims.
DenRS is offline
post #7 of 7 (permalink) Old Apr 29th, 09, 08:52 AM
Steiner
Originally Posted by BPOS View Post
X2
So that's why I couldn't afford a set and got the MB Wheels "Old School". American Racing must've wanted me to pay for all your lug nuts.
Steiner is offline
