Backspacing - Team Camaro Tech
post #1 of 11 (permalink) Old May 1st, 09, 04:03 PM Thread Starter
Chris
Backspacing
I am running 275,60,15 drag radials on the rear of my 68 camaro. I have them on 7" rims. They need to be on a wider rim. Was there a standard backspacing on 15x8, and 15x7 rims? Can you measure backspacing without taking tire off of rim?
hirpms is offline
post #2 of 11 (permalink) Old May 2nd, 09, 02:19 PM
Re: Backspacing
I run my 275/60/15 MT DR's on Weld Prostars 15 x 8 with 4.5" BS.
68 Camaro~LSx ~all motor
post #3 of 11 (permalink) Old May 2nd, 09, 02:21 PM
Lifetime Gold Member
Drew
ddx77's Avatar
Re: Backspacing
Awesome stance!
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #4 of 11 (permalink) Old May 2nd, 09, 05:54 PM Thread Starter
Chris
Re: Backspacing
Looks good Brother! Your set up much like me!
hirpms is offline
post #5 of 11 (permalink) Old May 2nd, 09, 06:24 PM
Lonnie
Lonnie P's Avatar
Re: Backspacing
Doug,
Any inner wheelwell modifications with your combo?
Trying to put something bigger under mine & do not want to hammer or cut anything.
Was looking at 275/50's or 60's. Probably need the 60's for traction but I want to keep the stock look to it.
Thanks,
Lonnie
Lonnie P is offline
post #6 of 11 (permalink) Old May 2nd, 09, 06:51 PM
Chris
Re: Backspacing
Doug G,is your car stock height in the back? I am going to run the same tire you have but want mine to be a bit lower,how far will it go down with that tire?caltrac has 1" and 2" drop built into there split mono setups but told me I would rub up in the wheel well with the 2" what do you think,Thanks
CMQuickcoupe is offline
post #7 of 11 (permalink) Old May 3rd, 09, 05:31 AM
Re: Backspacing
Same tire/wheel combo from when stock (mono springs bent) went to JCW 4-leaf replacement springs. Stock wheelwells inner and outer.
I'm looking into lowering the front (and maybe the rear too ?)
BTW, my driveway is not level so it does alter the stance a bit.
post #8 of 11 (permalink) Old May 3rd, 09, 07:16 PM
Lonnie
Lonnie P's Avatar
Re: Backspacing
The tires look mean under there.
I want to keep the look stock, but desperately need some tire under it.
These are stock 15x8 Vette wheels with 245/60's. I think they are 4" B.S. measured at the outer rim lip. (haven't measured them for about 15yrs.)
I definitely need more traction, but want the stock look.
Lonnie P is offline
post #9 of 11 (permalink) Old May 4th, 09, 02:34 AM
Re: Backspacing
275/60 will be about 1.5" wider overall.
post #10 of 11 (permalink) Old May 4th, 09, 07:16 AM
Vince
vincevs's Avatar
Re: Backspacing
I just did a lot of searching for these when I bought my rims. I purchased chrome 15X8 rally wheels with a 4.5" backspacing from coker. The painted wheels were a 4" backspacing so both could be considered "standard" but the 4.5" will pull your wheels into the fender a bit more and if I had to pick again I would still go with at least 4.5" as I am only running 245s. Good luck!
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #11 of 11 (permalink) Old May 4th, 09, 10:11 AM
Woody
Re: Backspacing
You need at least an 8" wide rear wheel with a 4.75 inch backspace. I am running 17x8's with 275/40R17's and it's a perfect fit with 4.75 backspacing.
bama_69 is offline
