back spacing on a 2nd gen rear in a 1st gen - Team Camaro Tech
post #1 of 6 (permalink) Old May 3rd, 09, 10:29 AM Thread Starter
i have a 2nd gen rear with disc in my 67 camaro. the rearend has disc brakes and measures 61 1/2 from hub to hub. my rally wheels rub the outer fenders some. there seems to be plenty of space to the inside of the rim. anyone running this set up and can comment on the bs they used. tire is a 265/60/15.
black 67 rs, factory power windows, a/c, deluxe interior, rear folding seat, tilt,power front disc brakes, speed warning, upgrades: four wheel disc brakes, factory tune port fuel inj., 700r4 over drive trans, electric cooling fans, 4:11 posi 12 bolt rear end, factory rated 300 hp 327,
airtime is offline
post #2 of 6 (permalink) Old May 5th, 09, 07:52 PM Thread Starter
Re: back spacing on a 2nd gen rear in a 1st gen
btt
airtime is offline
post #3 of 6 (permalink) Old May 5th, 09, 09:17 PM
I believe you can measure the distance between the inside sidewall and shock and use this measurement to increase backspacing accordingly. You would want to a min of 1 inch between the sidewall and shock, maybe 2 inches.
post #4 of 6 (permalink) Old May 6th, 09, 10:40 AM Thread Starter
i was thinking most people use a 5.5 inch back space on the rear. i was going to add another 1/2 to 3/4 of back spacing since my axle is a little wider than stock.
airtime is offline
post #5 of 6 (permalink) Old May 6th, 09, 10:56 AM
DjD
DjD's Avatar
This should help for figuring it out, just keep in mind shocks etc.
...Dennis
DjD is offline
post #6 of 6 (permalink) Old May 6th, 09, 12:48 PM Thread Starter
thanks djd. i'm thinking it's going to take a 17" wheel to clear the shock mount. i'm going to wait and see if the new hotchkis lower shock mounts are different than whats currently on the car. might go 15" old school buldge if i can as this will be more of a hotrod than corner carver.
airtime is offline
