Hub center bore - Team Camaro Tech
post #1 of 7 (permalink) Old May 11th, 09, 03:01 AM Thread Starter
Jakob
Hub center bore
Quick question for you guys. I need to get some hub centric rings for my Camaro, so I can have the BMW wheels mentioned in an earlier thread mounted.
What does the hub center bore / hub diameter measure on a 1st gen disc/drum (if there is any difference)? I would've checked this out for myself, but right now I am located far away from my car
Thanks.
'69 Camaro SS X22 - finally arrived
Pics and details coming soon
klartder is offline
post #2 of 7 (permalink) Old May 11th, 09, 04:16 AM
Re: Hub center bore
I have my GM rallys in the shed, as well as some front drum hubs, so I will break out my measuring caliper after I get the kids on the bus.
Eric
Eric Kammerer is offline
post #3 of 7 (permalink) Old May 11th, 09, 04:50 AM Thread Starter
Jakob
Re: Hub center bore
Thanks Eric
klartder is offline
post #4 of 7 (permalink) Old May 11th, 09, 07:32 AM
Re: Hub center bore
Look for it this evening. I didn't have time this morning (gotta work sometime, I guess ).
Eric
post #5 of 7 (permalink) Old May 12th, 09, 02:02 PM
Re: Hub center bore
Sorry, the post dropped off the "new" list and I forgot.
The hub diameter where the wheel sits is 2 and 13/16 inches, and the hub centric hole in the wheel is just a hair larger (my caliper is the old fashioned kind; a digital with enough decimal places would show some measurable difference).
If you find a good source for hub centric rings, could you please post back if it is located in the US? When folks have trouble with vibrations and other issues with lug centric wheels, it would be nice to have some help to offer.
Eric
post #6 of 7 (permalink) Old May 12th, 09, 02:09 PM
JohnnyRotten
Re: Hub center bore
these guys are in Florida...
http://www.justforwheels.com/index.jsp
SHIFTY4 is offline
post #7 of 7 (permalink) Old May 17th, 09, 02:44 PM Thread Starter
Jakob
Re: Hub center bore
Erik, thanks for the reply I have just tried searching for these locally and did indeed find a shop with many options. For you guys located in Denmark, check out: http://www.specialfaelge.dk/f%C3%A6l...ingsringe.aspx
klartder is offline
