4th gen wheels on a 1st gen - Team Camaro Tech
post #1 of 5 (permalink) Old May 13th, 09, 12:38 PM Thread Starter
i know this has most likely been covered a hundred times. i've seen it in magazines 6 years ago, but i cain't find it here by searching for 17 inch factory wheels.
so, what exactly do i have to do to put the chrome 17" ss wheels on my first gen. are the front wheels going to be to wide? my rearend is from a second gen so i'm 61 1/2 wid ein the rear now.
thanks
black 67 rs, factory power windows, a/c, deluxe interior, rear folding seat, tilt,power front disc brakes, speed warning, upgrades: four wheel disc brakes, factory tune port fuel inj., 700r4 over drive trans, electric cooling fans, 4:11 posi 12 bolt rear end, factory rated 300 hp 327,
airtime is offline
post #2 of 5 (permalink) Old May 13th, 09, 01:37 PM
Re: 4th gen wheels on a 1st gen
Some discussion buried in this thread: https://www.camaros.net/forums/showth...=4th+backspace
It's not so much an overall width issue, it is a backspace/offset issue. The fronts take quite a spacer to make fit, and that would scare me.
Eric
Eric Kammerer is offline
post #3 of 5 (permalink) Old May 13th, 09, 01:43 PM
DjD
DjD's Avatar
Not many 1st gens will run a 9" wide wheel on the front no matter what the back spacing without removing or modifying the inner fender. To bolt them up you need adapters not spacers. Figure on $200-300 for adapters just to get started then you have to deal with the inner fender on the front...
...Dennis
DjD is offline
post #4 of 5 (permalink) Old May 13th, 09, 01:47 PM
BILL
SPARKY69's Avatar
oh god no!! dont do it!!
SPARKY69 is offline
post #5 of 5 (permalink) Old May 13th, 09, 06:12 PM Thread Starter
i found a few post by searching 4th gen wheels. i prefer not to use the spacers/adapters. my rearend is 61 1/2 wide. that is not going to leave me with much depth in my rear wheels.
thats why i was thinking of going to a 4th gen wheel style. i guess my search continues.
airtime is offline
