Front tire size 69 model - Team Camaro Tech
post #1 of 8 (permalink) Old May 14th, 09, 03:25 PM Thread Starter
Can I use a 235x60x15 tire mounted on a 15x7 rally rim on the front of my 69 Z with factory suspension? Thanks!
dajlaw is offline
post #2 of 8 (permalink) Old May 14th, 09, 03:50 PM
Matt
Re: Front tire size 69 model
The tire easily fits the wheel. That won't be a problem.
Not sure on the clearances on the vehicle with this size but my guess is that it won't be a problem. Verify for sure.
_____________________________________________
1968 Teal Blue Metallic/Blue interior
327/210, 4-Speed Saginaw
Orig., #'s match engine, trans., driveline: 2nd owner
'68LL327 is offline
post #3 of 8 (permalink) Old May 14th, 09, 04:02 PM
Matt
For what it's worth as I am NOT a tire/wheel expert...I got wheels and tires just last week and wanted the 235 tire on a 7 inch wheel. I was told that even most shops will put a 235 on a 7 inch wheel, they prefer 8 inch wheel for that tire. I got talked into a 225 tires instead.
Matt
zlek131 is offline
post #4 of 8 (permalink) Old May 14th, 09, 06:35 PM
T
I ran this setup for a while on my '69, which is lowered a bit (1-2" or so?).
Had some light tyre rub on the frame at full lock but no major issues.
<Insert standard "every car is different, check your own" disclaimer here>
TMessick is offline
post #5 of 8 (permalink) Old May 14th, 09, 10:21 PM
FWIW, I run P235/60/R15's on a 15x7 Rally all the way around on my 1969 'Maro.....No issues!
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
post #6 of 8 (permalink) Old May 15th, 09, 03:52 AM
BILL
SPARKY69's Avatar
Yup..no issues
SPARKY69 is offline
post #7 of 8 (permalink) Old May 15th, 09, 09:01 AM
Dr. Feelgood
Originally Posted by zlek131 View Post
I got talked into a 225 tires instead...
That's a tiny tire...
'67 Buick Skylark F/C "Ingenue" 8/10 HRM feature / 2/12 Gasoline (Swedish) feature
World's only Buick-powered Buick Funny Car!
musclecarjohn is offline
post #8 of 8 (permalink) Old May 16th, 09, 10:14 AM
Matt
A 225 tire is 10 millimeters less than a 235 tire. 10 millimeters is 1 cm or 0.4 inches. So if a 225 tire is "tiny" then that makes a 235 tire a tiny bit bigger than a 225 tire.
Matt
zlek131 is offline
